Feilmelding på batterilader
maija27
Ingenting lever evig, selv ikke en Ctek lader...
Batteriene du har kjenner jeg ikke, men regner med de skal kunne brukes sammen med denne laderen?
Denne fra manualen til Ctek har du sikkert lest og sjekket:
Fault mode The charger goes to fault mode in the following situations: The battery is connected with poles reversed to the charger's terminals. The charger’s analysis function has interrupted charging. The terminals on the charger are short-circuited after charging has started. The charger has been in start mode for more than 4 hours
Redigert av Gudrun (see edit history)
