Antomic Startet 12.April Link til dette innlegget Startet 12.April Hei bare lurer men er det noen som vet hvordan justere ventiler på denne? eller har manualen til denne der det står ventil avstander? Mercedes Benz OM 352.1 fant dette på nett da: men stusse når jeg leser litt her. 0.20mm på intaket og 0.30 på uttaket. virker litt lite... Valve adjustment for the Mercedes-Benz OM352 (and 352.1/352A) diesel engine is a critical maintenance task for ensuring engine longevity and performance, usually requiring adjustment with a cold engine. The engine is a straight-six design, and regular maintenance prevents excessive ticking, power loss, and fuel efficiency drops. Valve Clearance Specifications (Cold) Intake Valve: 0.20 mm (0.008 inches) Exhaust Valve: 0.30 mm (0.012 inches) Note: Some sources indicate an allowable tolerance of +0.20 mm / -0.10 mm, but adhering strictly to 0.20/0.30 is standard for the OM352. Required Tools Feeler gauges 17 mm wrench/socket (for crankshaft turning) Valve adjusting tool/wrench (special, bent wrenches are often needed to access the adjustment nut under the rocker arm) Adjustment Procedure Preparation: Ensure the engine is completely cold. Remove the valve cover. Positioning: Rotate the crankshaft in the normal direction of rotation (clockwise) to bring the cylinders to Top Dead Center (TDC). Method 1: Individual Cylinder (Injection Sequence): Adjust each cylinder's intake and exhaust valves when the piston is at TDC on the compression stroke (both valves closed). Method 2: Two-Position Method (Common for 6-cylinder): Position 1: Set Cylinder 1 to TDC compression. Adjust: Intake: 1, 2, 4 Exhaust: 1, 3, 5 Position 2: Turn the crankshaft 360 degrees (one full revolution) to bring Cylinder 6 to TDC. Adjust: Intake: 3, 5, 6 Exhaust: 2, 4, 6 (Note: Verify exact valves using the firing order 1-5-3-6-2-4 if needed). Adjustment: Loosen the locknut (1) on the rocker arm. Insert the correct feeler gauge (5) between the rocker arm and the valve stem/bridge. Turn the adjustment screw (4) until a slight drag is felt on the gauge. Tighten the locknut while holding the adjustment screw to secure the setting. Final Step: Recheck all clearances to ensure they didn't shift during locking. Reinstall the valve cover. YouTube +4 Sitér dette innlegget Link to post
Antomic Svart 13.April Emnestarter Link til dette innlegget Svart 13.April det ordnet seg: fant det her: Sitér dette innlegget Link to post
