English: sabb H2 question
MtM
Hello, I am the owner of a sabb h2 and I like to speak/ write with some one who can help me with the sizes of the thickness of the dividing walls inside the propellor boss there is some wheare and I have to insert some thrust rings to fill it up, i live in Delft the netherlands
I am bussy to build in the engine in a open steel vlet of 6 meters we want to use it to go fishing with mental handicapt persons who live in the place where I work.
here you can find a picture of my boot please let me now if you can tell me the sizes that I like to now. I have also a picture of the engine. There is no indentification plate on it but i think it is from the early 80tees
love to here from you, greetings maarten
You will probably only require new original thrust rings. The metal does normally not wear much, it's the plastic parts (thrust rings) that takes the wear. New rings can be purchased from a Sabb dealer for a reasonable price. You need three rings, and they have to be cut open to be inserted. Easy job!
Hello MtM and index!
First, The 2H engine is an super engine. The best i know. All SABB motors are best.
index has right, but just two of the rings shall be cutted. One of them has to be put on when the propeller shaft is out.
As index told, easy job
Good Luck
Diesel248
Norsk motorhistorie --> Still going strong :smiley:
  • 4 uker senere...
Hello all of you sabb friend, thanks for all the awnsers you have given me!!!! I have done what you have advised me, three new rings and they are not cheep here in holland I think they have pulled my leg!!! I have payd 83,35 euroos for them but every thing is nice and tigd now so when we build th parts together I will be happy. Sorry that I have not send anny anwser earlyer but things to do places to go, you now what i mean. I will let you now in a few weeks, or month ,i am not so fast working hahaha, what the results will be. greetings to you all and please advise me about building in the Sabb 2h maarten
