VHF kanal 9 - Hva er spesielt med den?
Lazyjack
Det er mye info på nettet:
Boatsafe
Let me start by talking about the major channels that recreational boaters should be familiar with. The Federal Communications Commission has established VHF-FM channel 9 as a supplementary calling channel for noncommercial vessels (recreational boaters). A ship or shore unit wishing to call a boater would do so on channel 9, and anyone (boaters included) wishing to call a commercial ship or shore activity would continue to do so on channel 16. Recreational boaters may continue to call the Coast Guard and any commercial facility on channel 16.
The purpose of the FCC regulation is to relieve congestion on VHF channel 16, the distress, safety and calling frequency. FCC regulations require boaters having VHF radios to maintain a watch on either VHF channel 9 or channel 16, whenever the radio is turned on and not communicating with another station.
Warning: The Coast Guard announces urgent marine information broadcasts and storm warnings on channel 9 in the First Coast Guard District only (waters off the coast of northern New Jersey, New York, and New England). For that reason, we strongly urge boaters to use channel 9 in these waters. Use of channel 9 in other waters is optional, and we recommend boaters keep tuned to and use channel 16 in those waters unless otherwise notified by the Coast Guard.
Channels 9 and 16 are used for "hailing" (calling another vessel) only. Once you have contacted a vessel you should move your conversation to a "working channel". That is, one designated as "non-commercial" such as channel 68.
"hvis vannlinje er det viktigste.... kjøp en tømmerstokk" (Lano2)
Hei.
Når det gjelder bruk i Norge, og Europa ellers, gjelder:
Simplexkanalen K9 kan brukes som "skip til skip kanal, havnetjeneste i trange farvann og dirigering av fartøy" Skal kanalen kunne brukes som skip til skip kanal, gjelder følgende anmerkning: "Kan benyttes i områder der kanalen ikke er i bruk for havnetjeneste ol." Se ellers min oversikt om bruk av de maritime VHF-kanalene her. Og i printvenlig utgave her.
Det ble nevnt prioritet på skip til skip kanaler (men som for k9 kan det være restiksjoner på noen kanaler). Listen er fra høyest til lavest prioritet:
6, 8, 10, 13, 9, 72, 73, 69, 67, 77, 15, 17
Redigert.
Oversikt over US-kanaler og bruk finner du her.
Lars H.
Tja....alle VHF'er som skal bli lisensiert i Norge, må være CE-merket (merk at alle SOLAS-båter må ha ratt-merket utstyr). Videre må det fremgå av samsvarserklæringen hvilke standarder/direktiver den skal tilfredsstille (minimum R&TTE-direktivet, og dersom radioen har distress; minimum ETSI's standard for klasse D). Er vel ikke heeeelt sikker på at en importert radio fra f eks unaiten er CE-merket etc....og da blir'e itte noen EU-notifisering og ei heller mulig å få den registert hos Telenor Maritim Radio.
Mannskapet der vet nok det de trenger å vite om VHF og frekvensene.
I motsetning til den gjevne norske fritidsbåteier. (Svenske er sikkert enda verre). :lol:
men CE-merkningen har inget o gjöre med vem/vilken nasjonalitet det er på han/hun som snakker
det er dom fysiske kraven til radio-stasjonen........hvorfor ikke ha en Internasjonal standard???
CE-krav gjör att vi måste betale mer för en VHF-radio, enn om disse radioer kunde marknadsföres/selges over hele Verlden... :yesnod:
S/Y Gunga Din
Yo, den store båten faller nok under IMO's SOLAS-krav, og benytter typegodkjent RATT-merket utstyr....hvorvidt CE-merking er tull eller ikke får hver enkelt gjøre seg opp en formening om....men det er nå bra at ITU og ETSI lager hhv funksjonelle krav og test-krav for bl a radioutstyr, basert på IMO sin retningslinjer. Og det er bla disse som legges til grunn ved notifisering av utstyret. Ellers ville det vært veeeldig mye rart på markedet...tro meg.
