Walter_S Startet 6.Mars.2009 Link til dette innlegget Startet 6.Mars.2009 Hei folkens! Nå må vi vise til hva vi duger og hvilken BP-ånd vi kan klare å mønstre. Der sitter TK (Tobis K?) i Bremen / Tyskland og trenger deler til sin tilårskomne 2-sylindra FM bensinmotor - type L2 (ifg. han selv). Det han trenger er et ekshaust-manifold Han har tidligere prøvd å få hjelp her, men i det engelsk-språklige forum, men har nå sendt en IM direkte til meg, fordi ingen ser ut til å lese (eller forstå?) han rop om hjelp. Her er hans opprop: Exhaustbend for FM Type L-2 and other parts Han har nå gitt meg tillatelse til å offentliggjøre denne IM'en, slik at flere forstår hvilken vanskelig situasjon han er i. 27. februar 2009 Hi WalterIt is me Tobias, if you renember the guy from Germany. I put this message into the english forum but unfortunately nobody is answering. Could you help? Hello everybody While overhauling my FM L-2 I have found out that my Exhaustbend has a hole due to corrosion. Does anybody has one in spare. I am also interested in other parts like the housing for the thermostat and the pipes for the cooling water. These parts does not have to be new but in good shape of course. I am thankfull for any help. Thank you soo much. Mayby we will spend our holiday in Norway, who knows eventually we are also in your region. Greetings Tobias Og denne her fikk jeg i går...: Hi WalterThank you for answering. Unfortunately I donot have any spare parts numbers. I am/was in Contact with "Mekkern" a specialist for FM who claims to ahve any spares in stock but he is only answering my mails if he has nothing else to do. That means maby 4 times a year. As I understood the FM L-2 was build the same way for decades. Mine is from 1970, mayby you can mention that in the Apent forum. Everybody is welcome who has parts for the L-2 is welcome. The most wanted parts are the cooling pipes and I mean everyone and the exhaustbend. Every other problem is more or less solved. The forgasser and the cylinder head is like new again. The Dynastarter is also almost ready. The magneto and the regulator is next. So, yes please put my question in the open forum. I will put my request into the buy and sell forum. Thanks a lot and good luck for your work. Greetings from Bremen Hvor det da går frem av at han har vært i kontakt med 'Mekkern' (http://www.mekkern.com/), men at 'Mekkern' ikke "orker" å svare Tobias - (mulig at det er noe språkforvirring ute og går også...) fordi denne har for mye å gjøre. Problemet er selvfølgelig at Tobias ikke har nøyaktig delenummer på de delene han trenger, og det gjør jo ikke saken enklere. Noe som kan / har delere? Sitér dette innlegget Medlem i Søndre Kråkerøy Båtforening og "Vraktangen Dram- og Lutefisklag" Påstand: Isskrape er også båtutstyr! :o) HADDE tresjark og Sabb 10hk G-modell fra 1990 MED HERLIG LYD! - Har nå konvertert til PLAST! Tromøy 23 m Sabb 2H fra 1975 Walter's HJEMMESIDE ><((((º> Link to post
tom-ass Svart 6.Mars.2009 Link til dette innlegget Svart 6.Mars.2009 Er det nye deler han skal ha? Sitér dette innlegget Bygdetulling med båtførerbevis! Link to post
Walter_S Svart 6.Mars.2009 Emnestarter Link til dette innlegget Svart 6.Mars.2009 Jeg tror han tar det han får tak i. Det er jo ikke akkurat flusst med deler i Tyskland.... Sitér dette innlegget Medlem i Søndre Kråkerøy Båtforening og "Vraktangen Dram- og Lutefisklag" Påstand: Isskrape er også båtutstyr! :o) HADDE tresjark og Sabb 10hk G-modell fra 1990 MED HERLIG LYD! - Har nå konvertert til PLAST! Tromøy 23 m Sabb 2H fra 1975 Walter's HJEMMESIDE ><((((º> Link to post
Per Harald Svart 7.Mars.2009 Link til dette innlegget Svart 7.Mars.2009 Hei Walter_S Du kjenner jo Per Øystein Andreassen. Jeg regner med at du har forhørt deg hos ham? Om ikke så er det et tips. Når jeg pratet med ham sist så fikk jeg forståelsen av at han puslet litt med FM motorene i kjelleren enda. Jammen måtte jeg opp med boka til Per Øystein å lese om L2 motoren. Bare måtte. Per Harald Sitér dette innlegget https://baatplassen.no/i/blog/per_harald/index.php? Vis hensyn på sjøen. Ja til obligatorisk båtførerbevis. D5LA I boks. Link to post
«Sjøbris» Svart 7.Mars.2009 Link til dette innlegget Svart 7.Mars.2009 Hei Walter S Har du hørt med Petter i Tøffe? Sitér dette innlegget Link to post
Roger jo Svart 7.Mars.2009 Link til dette innlegget Svart 7.Mars.2009 her er en med orden i sysakene http://www.mekkern.com/FM.htm Sitér dette innlegget Kokekyndig maskinist kjent på kysten. Link to post
Walter_S Svart 7.Mars.2009 Emnestarter Link til dette innlegget Svart 7.Mars.2009 (redigert) Noe av poenget her er jo at jeg personlig ikke kan gå på jakt etter deler. For det første kjenner jeg ikke FM-motoren noe særlig. Ser ikke forskjell mellom en L2 og S2 en gang. Problem nummer 2 er at Tobias ikke har original delenummer på de(n) delene(e) han skal ha, og da er det fort gjort å ende opp med feil del.....det skal jo (mest sansynlig) sendes til Tyskland også....! Skjønner du / dere. Jeg vet heller ikke HVORFOR Tobias har sendt denne IM'en akkurat til meg!? Mulig fordi jeg svarte på en god del spørsmål i det engelske forumet for ca 1 år siden, men da gjaldt det en Sabb dieselmotor, noe jeg føler meg mere kompetent på å snakke om. Jeg har, i dette tilfelle her, kun sagt meg villig til å offentliggjøre forespørselen hans i det Engelske Forumet, her i ÅF, slik at eventuellt andre kan svare han / hjelpe han / råde han der. Jeg vil ikke bli sittende med ansvar for noe jeg ikke kan noe om! Det føler jeg meg ikke vel med. her er en med orden i sysakenehttp://www.mekkern.com/FM.htmhttp://www.mekkern.com/FM.htm Det er greit at "Mekkeren" har orden på saken. Men sannheten er jo at Tobias HAR vært i kontakt med han (Se tråden: FM Motor Type L 2 Questions), men Mekkeren svarer ikke på forespørsel på en for han ukjent mann i Tyskland som fremsetter sine spørsmål på engelsk. Jeg forstår det på en måte også, det kan lett bli klabb-og-babb ut av en slik kommunikasjon, med missforståelser, spesiell siden Tobias ikke har delenummer. ... Redigert 7.Mars.2009 av Walter_S (see edit history) Sitér dette innlegget Medlem i Søndre Kråkerøy Båtforening og "Vraktangen Dram- og Lutefisklag" Påstand: Isskrape er også båtutstyr! :o) HADDE tresjark og Sabb 10hk G-modell fra 1990 MED HERLIG LYD! - Har nå konvertert til PLAST! Tromøy 23 m Sabb 2H fra 1975 Walter's HJEMMESIDE ><((((º> Link to post
Tk Svart 7.Mars.2009 Link til dette innlegget Svart 7.Mars.2009 (redigert) Hi Walter Thank you very much for your help so far. I got a tip already to find some used parts in"Horten", so not very far from your place as I renember. I have send him an email and I hope that he will answer. Again thank you!! Greetings Tobias Redigert 7.Mars.2009 av Tk (see edit history) Sitér dette innlegget To have it, is better then to need it! Link to post
