17 volt på mercury påhenger
trulssyv
Kostet sånn ca kr 2000 hos Honda i for 10 år siden :rolleyes:
Mercury#881346T koster 1194.57 +MVA ( Ravns Garage ) ( Mercury 4-Takt EFI 2004 )
Ifra manual
1. Check battery voltage at battery with engine running.
2. If battery voltage is above 14.5-15.0 volts, replace voltage regulator/rectifier. Check condition
of battery as overcharging may have damaged battery.
3. If battery voltage is below 14.5 V charge battery. If battery can NOT be satisfactorily
charged, replace battery.
Arne Kjetil
