Digitale instrumenter Yamaha
Gilbert21
Klippet fra et annet forum:
yellow is key on 12+, dark green is tach send, blue at the gauge is light, black is ground. white with blue stripe is for the yamaha fuel sender white is for most other senders, red is 12v+, grey is for overheat visual,. if the gauges are pre 95 models it will all have the same color codes. dont mistake the ligth blue and light green trim wires for gauge wires.
Share on other sites
sjekk dokumentarkivet, har lagt inn installasjonsveiledningen der i pdf format
Join the conversation
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
