Digitale instrumenter Yamaha
Gilbert21
Klippet fra et annet forum:
yellow is key on 12+, dark green is tach send, blue at the gauge is light, black is ground. white with blue stripe is for the yamaha fuel sender white is for most other senders, red is 12v+, grey is for overheat visual,. if the gauges are pre 95 models it will all have the same color codes. dont mistake the ligth blue and light green trim wires for gauge wires.
