Hvor er dette?
bliss X
Tror dere er for opphengt i ordet "Porto". Stedet heter Porto og ligger på en øy som er restene etter "Tyrrhenia". Dette var et stort rike/samfunn som forsvant i oldtiden. Tyrrhenia kunne ha vært på størrelse med Corsica. Havet som omkranset dette samfunnet fikk navnet Tyrrhenia og restene av denne store øya ligger der fortsatt og Porto ligger da på øya *****
:yesnod:
Surtsey (Icelandic: "Surtur's island") is a volcanic island off the southern coast of Iceland. At 63.400, -20.300 it is also the southernmost point of Iceland. It was formed in a volcanic eruption which began 130 meters below sea level, and reached the surface on 14 November 1963. The eruption may have started a few days earlier and lasted until 5 June 1967, when the island reached its maximum size of 2.7 km². Since then, wind and wave erosion has seen the island steadily diminish in size: As of 2007, its surface area is 1.4 km² in size.
Redigert av jawik (see edit history)
******** is the first fully rigged square-rigged ship with five masts since the Preussen, launched in 1902, one of the last sail powered bulk cargo ship. The Preussen was then the largest and fastest sailing vessel ever built.
Dette var den gang...
I dag derimot er skipet...
