Benton BX-2 elektronisk batterilader kontra CTEC
Tjond
Det jeg ble litt hekta på var at den også har har innebygd "Power Supply (Works as power generator, 13.6v/5A.)
Kommer i postkassa til den nette sum av Kr 421,- fant jeg ut. Kanskje ikke noe røverkjøp, men....
Ellers sakset fra skrytelista til en nettbutikk jeg fant som solgte den(omregnet til NoK ca 900,-):
SPECIFICATIONS
Input Voltage - 170 - 260VAC, 50/60Hz
Output Voltage - 12V & 24V (auto-select)
Input Current - 1.5A RMS max
Efficiency - >75%
Charging Voltage - 28.8V+-0.25V or 29.4V+-0.25V or 14.4V+-0.25V or 3.6V+-0.25V or 16.5V+-0.25V
Charging Current - 7.0A+-10% or 5.0A+-10% or 3.0A+-10% or 1.5A+10%
Back Drain Current - 5mA
Ripple - Max 150mV,0.3A
Ambient Temp - -20degC to +50degC/-4degF to 122degF, Reduced output power at higher temperature
Charger Type - Seven step, fully automatic, switch mode with maintenance charging
Battery Types - 12V & 24V lead-acid batteries (WET, MF, AGM and GEL)
Battery Capacity - 14-230Ah (for 12V), 14-120Ah (for 24V)
Dimensions - 201x91x51mm
Housing Protection - IP65 (Dust and Splash proof) Outdoor use
Weight - 0.912kg
Noise Level - <50dB (tested from a distance of 50cm)
The Benton battery charger BX2 is supplied with 2 detachable and interchangeable colour coded lead sets one with clamps for bench charging and one with eyelet terminals (0.63mm) with in line battery protection plug in fuse (10A) for permanent attachment to the battery posts to allow quick connection/disconnection through snap-connector.
Trond Haug
