Clas Ohlson GPS mottaker, musa hopper...
Båtfareren
Problemet med "hoppende mus" er også kjent ved bruk av Maptechs Offshore Navigator (OSN),
se http://www.maptech.com/support/doc.cfm?docid=60
TITLE (printable format) (email this document)
Jumping Mouse
Created: 12/05/2003
Modified: 08/26/2004
TOPIC
When connected to a GPS, the computers mouse acts erratically and seems to be 'jumping' around
DISCUSSION
A Windows bug has recently been discovered by Microsoft where Windows detects a connected GPS as a mouse--this produces a jumping cursor problem. The following are the directions supplied by Microsoft support to correct the problem:
1. Turn off the GPS and close Maptech Navigator Software.
2. Right-click on the My Computer icon and select Properties.
3. Select the Hardware tab, and click the Device Manager button.
4. Next to "Mice and other pointing devices," click the plus button to expand this list. You should see at least two items listed. One is the mouse you normally use, and the other will probably be listed as "Microsoft Serial Ball Point."
5. Highlight "Microsoft Serial Ball Point" and click the Disable button at the top of the window (it is usually the second button from the right; hover the cursor over it and read the ToolTip to verify).
6. In the confirmation message window that appears, click Yes.
7. Close the Device Manager.
8. Plug in/turn on your GPS.
9. Restart Maptech Navigator Software.
If these steps do not correct the issue, you will want to contact the computer manufacturer for more trouble shooting help.
Redigert av roaldbj (see edit history)
Kunne ikke annet enn å smile litt når jeg så denne her:
A Windows bug has recently been discovered by Microsoft....
"Recently" betyr når Windows2000 ble lansert og Microsoft har enda ikke løst problemet..... MS har til og med laget et kryptisk DOS-program for å løse dette her i Windows men det virker ikke hos meg, på lik linje med de andre MS-løsningere..... Den eneste løsningen på dette problemet er den som roaldbj har kommet med. Og for å presisere litt: Dette har INGENTING men GPSen til Clas Ohlson eller Maptech å gjøre, det er Windows som tolker NMEA-data fra en hvilken som helst GPS som noe som bør bekandles som mus dermed blir "Microsoft Serial Ball Point" musdriver installert og muspekeren går helt bananas....
Eg hadde nett store problemer med å få mi GPS mus til å virke, eg trodde da at det var musa det var noe gale med. Fekk eit tips om å prøve å legge musa ut vinduet, det løyste problemet og posisjonen min kom opp på C-Map. Så musa må ha fri sikt.
Kan du forklare dette noe mer?
Selve GPS senderen må være utendørs, den bør ha god horisont, dvs vegger og store trær bør ikke skygge for GPS mottageren.
Du kan laste ned SA-Watch http://gpsinformation.net/main/sawatch.htm
eller bruke hyperterminal til Microsoft for å se hvor mange sattelitter du har tilgang til.
Du mener vel mottakeren? :wink:
Min Haicom USB ligger og slenger på dashboardet under frontruten. Har aldri hatt noe som helst problem med å få signal.
Skipper_Worse, takk for påminnelsen.
Selvfølgelig er det mottakeren det dreier seg om.
Mitt poeng var at bl.a. hyperterminal er egnet til å se signalene direkte uten påvirkning av "filtre".
Igjen takk for korreksjonen.
Det er sannsynelig at din datamaskin tolker GPSen som en mus.
Microsoft har laget et verktøy for å ordne dette.
Jeg har gjort dette en gang på en maskin og brukte veldig lang tid. Husker heller ikke hvordan jeg fikk det til.
Mener at jeg måtte lage en virituell COM port siden USB porten ikke tolker signalene riktig.
Kikk på denne linken.
http://support.microsoft.com/default.aspx?...kb;en-us;819036
