doctordre
doctordre
Prepaired for launch.
My brother made a scketch of the spacers.
It took just 4 days, before we got the back. It fitted perfectly, unfortunately  I had forgotten the thickness of the exhaust bellows. So I came 3 mm short between the engines.
we modified the spacer and after another two days they were finished.
That was last weekend. Just had to wait for a new set of gaskets.
So on Tuesday the gaskets arrived and everything is now fixed.
The picture is dark because is was 21:00 when it was finished.
Yesterday checked all the fluid levels. and started everything up.
Everything is running well. (video coming soon)
There still are some flaws in the software which will  be done this week. And coming Friday most likely the
maiden launch.
doctordre
doctordre
It took just 4 days, before we got the back. It fitted perfectly, weren't it that I forgot the thickness of the exhaust bellows. So I came 3 mm short.
IMG_5478.jpg.681c0e65d130896bfd71c2a6a0942e9b.jpgIMG_5479.jpg.c761db9a3d54396744d2cd5df3d577a4.jpg
maiden launch.
