doctordre
doctordre
winter time means tinker time.
I made a new display that is sunlight readable and is protected against water.
ofcource with CANbus(2x) with finally a boot loader. so programmable via canbus
but all electronics is now inside the box.
resolution is a bit better 800x480 instead of 600x480.
The rest is almost the same.
you see a lot of wires
but it has about 10 inputs and outputs and there is a possiblity to connect to a camera
doctordre
doctordre
