doctordre
to Pero:
Thanks. Just keep in mind the first rule of technics: IF IT IS NOT BROKEN DON'T FIX IT.
I think i never stop changing things. electronics is an even great hobby as boating, maybe even bigger.
To kanalkapteinen
Also thanks. i used it not so much as i would like but since the launch about 300-350 engine hours.
I used the boat more but usually we go somewhere to the beach or forest which is just a few kilometres from here. The advantage of a small county. To make a trip through the forest is about two hours due to speedlimit(~9km) and then we hang around and get some sun.
Hydrogen is still the plan. But there are still a lot of things to do. like new trim tabs.
And as for the generator. The original exhaust is just a little cap with two screws. a friend copied that but added a little piece of pipe to it so i could connect it with a flexible exhaust and a heat protection around it and drilled the hole thru the hull . between the registration number.
will be continued..
