tommy-be Startet 4.Mars.2019 Link til dette innlegget Startet 4.Mars.2019 (redigert) Hello my name is Thomas, I'm from Stralsund, Germany and some weeks ago I bought a small, open, wooden boat in Kristiansand, Norway. The boat is equipped with an 1-cylinder-engine, made by FM Motor in Fredrikstad, Norway. Meanwhile we get the engine running, but unfortunately there is a lot of oil coming out of the snorkling valve. Maybe there is too much oil in the engine, maybe there is anything wrong with the snorkling valve. Another triggy point is the connection between the gear box and the propeller drive shaft, as well as the connection between the pitch lever and the tube around the shaft which differs the pitch of the propellerblades. It would be nice if anyone has some helpful ideas to fix the problems. Maybe there are some pictures, photos, videos or drawings to see how it should work. Thank you for assistance and many greetings from Stralsund Thomas. Redigert 4.Mars.2019 av tommy-be update by photos (see edit history) Sitér dette innlegget Link to post
Nero II Svart 4.Mars.2019 Link til dette innlegget Svart 4.Mars.2019 Hi, nd congratulations on a classic motor. I cannot comment on the oil problem, as I have no experience. As for the shaft - in Norwegian "aksling"- connecting motor and propeller, I was always taught that the inner shaft is for the pitch, and the outer is for the propellers. In other words both need to be connected to the motor. It looks to me as if you lack a House - in Norwegian "flens", which has the function of links the aksling to the motor. If you look at the end of the motor oil your picture above, you will notice that there is an circle around the hole for the aksling. This is where I would guess there should be holes for connecting the aksling to the motor. Is there holes in their ring for bolts holding this connection together? If there are no holes, my assumption of a lacking flens is probably wrong. Sitér dette innlegget Link to post
Stekepanne Svart 5.Mars.2019 Link til dette innlegget Svart 5.Mars.2019 When oil is coming out of strange places (example not the oil pan gasket) you most often have a problem with pressure. This pressure can come from too much oil (as you said), a blocked “breathing hole”, or the one a bit worse: exhaust into the engine. On newer engines the “breathing hole” is almost always the EGR-valve. Exhaust inside the engine can come from a number of things: blown head gasket, bad exhaust valves or bad piston ring/worn sylinders. I would suggest a compression test Sitér dette innlegget Link to post
ulsetbåt Svart 5.Mars.2019 Link til dette innlegget Svart 5.Mars.2019 This engine has no oil pump, so there is no oil pressure. Oil coming out of the snorkeling valve means that there is too much oil in the engine. Sitér dette innlegget Link to post
Stekepanne Svart 5.Mars.2019 Link til dette innlegget Svart 5.Mars.2019 8 minutes ago, ulsetbåt said: This engine has no oil pump, so there is no oil pressure. Oil coming out of the snorkeling valve means that there is too much oil in the engine. Aaah, that makes quite a big difference :) Sitér dette innlegget Link to post
tommy-be Svart 5.Mars.2019 Emnestarter Link til dette innlegget Svart 5.Mars.2019 Hello, first of all many thanks for all these interesting inputs. So we should try it with less oil. For the gearbox-propellershaft connection a photo from any other boat with the same system would really helpful. Is there any picture available? cheers th. Sitér dette innlegget Link to post
shipahoy Svart 5.Mars.2019 Link til dette innlegget Svart 5.Mars.2019 Is it a fixed pitch or adjustable pitch propeller? There is a picture in the "FM C & D serie brosjyre" in this page http://www.fm-motor.no/publikasjoner.htm. Sitér dette innlegget Link to post
tommy-be Svart 5.Mars.2019 Emnestarter Link til dette innlegget Svart 5.Mars.2019 Thank you I found it already, but no idea how it looks like, how it works and how it is fitted to the pitch lever. The propeller pitch is adjustable. Sitér dette innlegget Link to post
