Erstatte rekkewire med stiv reling
Kappa
Funderer på en ide om å erstatte den øverste rekkewiren med fast reling. Tenker syrefast rør á 25 mm eller kanskje teak. En fast reling blir jo mer stivt og håndfast. Dessuten kan en fast reling brukes til å feste ting, f.eks. solpanel. Men kanskje vanskelig å få en fast reling til å bli pent. Har idag vanlige rekkestøtter for wire, og bildet viser hvordan et rør kan festes i toppen.Noen som har prøvd seg på dette?
Jeg har vært inne på samme tanke, men bare for den del som er ved cockpiten. Jeg fant denne artikkel hvor de har løst det på en elegant måte.
P1030548-e1504663354573.jpg?resize=800%2
UPGRADED STERN RAILS AND LIFELINES
September 6, 2017
We recently completed upgrades to the aft lifelines of Alembic. Our goal was to add a mounting place for solar panels as well as to increase safety and security. First we added a stanchion just aft of the mizzen shrouds. We then added top and mid rails using 1″ SS tube and associated fittings. We connected these rails to the stern pulpit using hinged connectors (see photo).  After locking everything together with the mechanical set screws at the fitting joints, we took the stanchion and rail assemblies to a local welder to weld solid all the joints between tube and fittings.  The overall stern railings and pulpit are comprised of 3 sections.  There are the two aft quarter sections that are the stanchion and rails as a welded assembly and the original stern pulpit.  The side rails connect to the stern pulpit at the hinged connectors shown in the photos.  The rail sections on the aft quarters provide an excellent place to mount solar panels on hinged mounts.
P1030549.jpg?resize=300%2C225&ssl=1
100 Watt solar panel mounted to stern rail
fullsizeoutput_1.jpeg?resize=300%2C260&s
Hinged Connector to connect side rails to existing pulpit
P1030708.jpg?resize=300%2C225&ssl=1
Rail connection to existing stern pulpit
We terminated the rail sections with anchor points to support the attachment of lifelines.  We replaced the wire lifelines with Dyneema line. Finally, we added a section of 1″ SS tube along the cockpit exit for additional security when entering and exiting the cockpit. This is a fairly easy installation using “90 deg T fittings” placed on top of existing stanchions to connect the 1” SS tube.  The Dyneema line extends through the center of this tubing section for added security.  A key fitting in this assembly is the “90 deg T fitting with anchor” (see photo) to support the connection of the lifeline gate.  This particular fitting is supplied by Sea-dog and was a special order item at my local marine store.
P1030548.jpg?resize=300%2C225&ssl=1
Solid section of lifeline at the exit of the cockpit to the side deck
P1030551.jpg?resize=300%2C225&ssl=1
The Dyneema line extends through the SS tube
P1030550.jpg?resize=300%2C225&ssl=1
Dyneema line connects to a turnbuckle then to the stern rail
fullsizeoutput_3.jpeg?resize=292%2C224&s
T Fitting with Anchor for Connecting Lifelines
The upgraded stern rails and lifelines enhance the  safety and security of Alembic.  Support solar panel mounting was also very important to us.  With our mizzen mast, adding an arch to hold solar panels is not a simple installation.  We also have a canvas bimini so adding panels over the cockpit is also not an easy solution.  Given these constraints, the stern rail mount is a great option.
Kappa skrev 57 minutter siden:
Jeg har gjort dette. Det ble veldig vellykket, en av de beste oppgraderingene jeg har gjort med båten. Se tråd under der jeg beskriver jobben. Bonus var at jeg fikk utbedret flere små lekkasjer jeg ikke visste om, og at jeg fikk ca. 7cm breiere dollbord. Det siste der utgjorde veldig mye!
alfaalfa skrev 54 minutter siden:
Jeg ville tro at krummingen på røret som skal være reling er vanskelig å få til å passe profilen på rekka på båten.
Se hvordan jeg løste det med rørbøying og krumning i tråden under. Det var enklere enn jeg hadde sett for meg. Rigget meg til med et enkelt verktøy etter tips fra en kompis. Tilpasninger ble gjort på stedet.
Komodo skrev for 1 time siden:
Fantastisk jobb og bra resultat!  - med innsikt og litt (godt med) tid så går det faktisk! Imponert!
På båten min er det stiv rekke på akterdekk, og støtter med wire derfra, og frem til baugen (puch eller pullpit?)
Kan godt tenke meg stiv rekke, der jeg tar tak i rekka når jeg skal på dekk, eller fra brygga, og opp i båten. Muligens hele veien til enden av dekkshuset( Motiva 43 Seilbåt med dekksalong)For så vidt en løsning som er avbildet i innlegget til Komodo. Dynema istedenfor rekkewire ser også fristene ut. Da må man vel bare flettespleise inn på en terminal som passer i strekkfisk/på rekkestøtte. Er det noen skjulte bakdeler her? UVR, skamfiling?
