Knapply Startet 1.Mai Link til dette innlegget Startet 1.Mai Hello everyone! For our first boat we bought a used Askeladden Chaser 445 2005 with Mariner F50. My questions are regarding the electrical system: I cannot find any fuses anywhere, should there be some? There is a Main on/off stitch next to the battery but that is all I have found, should I consider installing simple fuse box? I want to add a gps/ekkolodd so am also wondering where I would connect this ? Any help, advice, comments or pictures of other Chaser fuse systems would be greatly appreciated. Feel free to reply in Norwegian, thank you! Sitér dette innlegget Link to post
fritidsfiskeren Svart 2.Mai Link til dette innlegget Svart 2.Mai If there is anything consuming power (other than the engine), it should have a fuse. If you install new gadgets (gps/ekkolodd), they should have a fuse as close to the battery as possible. Sitér dette innlegget Link to post
Knapply Svart 2.Mai Emnestarter Link til dette innlegget Svart 2.Mai Thanks fritidfiskeren! I will take that on board 🙂 Have purchased a fuse block unit from the Biltema Sitér dette innlegget Link to post
Fantino Svart 2.Mai Link til dette innlegget Svart 2.Mai GPS/depth sounders may consume considerable power so make sure you have sufficient battery capacity to ensure start (unless the engine can be hand cranked?) if the gadgets will be used without engine running. Sitér dette innlegget Link to post
Knapply Svart 2.Mai Emnestarter Link til dette innlegget Svart 2.Mai Thanks for the good tip Fantino! Sitér dette innlegget Link to post
Ingar Svart 2.Mai Link til dette innlegget Svart 2.Mai Fantino skrev for 7 timer siden: GPS/depth sounders may consume considerable power I tested this earlier with a 9" Lowrance and it only drew 0.61 Amp at 12.7 volt. (With max backlight and transducer connected). Specifications says 1.5 Amp. Sitér dette innlegget Link to post
