Om garmin`s plottere, hovedsaklig: 420/520/525 og S
KenBjork
Noen som vet om det finner en måte, så plotteren kan brukes innom hus. Tenker på strøm forsyning
Jeg har garmin 520S.
Jeg har en 525, det er vel mye det samme. Bestilte ekstra kabel sett og monterte på "lighterplugg" Og plugget inn i 12v omformer fra "gubbdagisen" les Clas Ohlson.
Funker helt fint.
Jeg har forresten også måttet oppdatere programvaren. Lastet ned i en ekstra minne brikke, og lastet inn. Virket også helt greit.
:smiley:
  • 4 uker senere...
Hei
Nå er det enda en ny softwareoppdatering kommet til 420/520/525 og S
http://www8.garmin.com/support/blosp.jsp
Changes made from version 2.80 to 3.00:
* Added Turkish translations.
* Added a trip numbers page.
* Sped up imagery drawing.
* Improved Mariner's Eye and Fish Eye operation and appearance.
* Improved positioning of depth contour labels.
* Added waypoint decluttering.
* Sped up track-up drawing.
* Added bridge and overhead cable clearance to corresponding review pages.
* Added support for showing position overlay number on navigation chart when sonar isn't available.
* Corrected the IOS tide station drawing.
* Added sonar cone coverage to the A-scope and Custom numbers selection.
* Sped up Auto Guidance searching when there is no solution.
* Reduced the width of the track line for better viewing.
* Improved digital data appearance on the flasher page.
  • 3 måneder senere...
Hei
Changes made from version 3.00 to 3.10:
* Added fuel management features for use with Garmin CANet-capable fuel sensors
* Added TracBack support and the ability to navigate to a specific track point
* Improved map drawing performance
* Added a control for overlay numbers on the Chart/Sonar pages
* Added the ability to create a new waypoint or route from the user data and Where To? lists
* Added the ability show trip and fuel numbers on the custom numbers page
* Improved the look of the pile, artificial reefs, and algae blooms symbols
* Added the ability to scan a track from the map
* Modified Home key function to be more user friendly when pressed on the Display adjustment page
* Searching... is now displayed while a search is active instead of None Found.
* Improved scanning of route waypoints
* Improved the placement of the boat when sailing or fuel numbers are displayed
* Corrected PGRMM and PGRMZ NMEA controls as they were swapped
* Fixed problem that was causing Loran TD changes to not be remembered between power cycles.
* Corrected an issue when merging user data where a routes or tracks with the same name could be overwritten
* Fixed problem with on-route waypoint navigation
* Corrected AIS vessel descriptions that are displayed on the AIS review page
* Added 'Observatorio 1966' map datum
* Corrected how safe zone rings are drawn when using metric units
* Allowed extended characters to be transferred in waypoints, routes, and tracks
* Added support for wind and volume units.
* Corrected issue where the depth units may not be able to be set if connected to a GSD-21
* Corrected issue where the review button on the DSC message banner may bring up the wrong review page if several DSC messages had been received
* Added Polish language support and translations.
Den er grei ja :cool:
Det er vært såpass viktige oppdateringer på denne serien til garmin at jeg har valgt å endre emne-tittel og bruke den bla til å varsle om oppdateringer til disse.
Kommer nok til å fortsette med det også.
  • 2 måneder senere...
Hei.
Har funnet ett problem i siste firmware v3.10
Er det noen andre her som har merket noe?
For øverig så har jeg akkurat nå sendt garmin mail.
Orker ikke skrive alt på nytt på norsk til dere, så dere får se mailen.
Mulig noe dårlig engelsk, men håper de forstår, og at dere her inne skjønner det også :wink:
Men inntil videre, så dere som ikke har oppdatert til v3.10, vent med det til jeg får svar fra garmin. kommer til å poste svaret her.
Ok, mailen som er sendt til garmin:
Hi
It`s an bug in latest firmware v3.10 that messes up routes. Earlier the saved routes were in meny "where to go > routes"
After latest update it split/moved som off the routes to "user data>routes"
And the routes here are not prossesed correctly, when chossen navigate. Seems like it jumps back and forward between different waypoints. And the cursor that point out off course, point directly to end destination.
But navigate after the routes that are find in "where to go > routes", they are prossesed correctly bye the plotter, and can navigate after it correctly.
Hope it wil be released an fix for these problems fast.
Sorry if my english is not quite correct.
Mvh Kenneth
  • 2 uker senere...
Svart (redigert)
Vet jeg har fått svar, men har ikke klart å lese svaret inne på kontoen. Får feilmelding ved lasting av meldinger.
Er vært treigt også på garmin siden i sener tid, og de har vel noen språkoppdatering stod det om blant annet tidligere.
Og nå kommer jeg heller ikke inn på konto lenger.
Garmin
Site Upgrades in Progress
We're currently making upgrades to the site to improve the experience
for our visitors. We apologize for the inconvenience. Please check back
shortly as we plan to have the upgrades completed soon.
Thank you.
Jeg har ikke funnet annen bug i firmware v3.10, annet enn den jeg har nevnt i forje post.
Så om man ikke har masse ruter fra før som man kan risikere å plotte på nytt, så kan man nok oppdatere fw.
Redigert av KenBjork (see edit history)
Jeg oppdaterte til 3.10. har ikke merket noen problemer med den opptaterte versjonen.
Svart (redigert)
Så fint å høre da.
Men alle rutene dine låg da vel under "hvor skal du > ruter".
Har du prøvd og nå da med "brukerdata > ruter" gå til den meny og velge rute og navigere til derfra?
Også om alle rutene du lagret som er under "hvor skal du > ruter" også om du finner de allesammen under "brukerdata > ruter"?
Ja har brukt plotteren mye siden den ble kjøpt ny i Påsken. Har lagt bak meg 200 nm mil på 4 uker så da er vel plotteren vellært og forstått. Ikke alt selvfølgelig men det mest brukte og mest brukervennlige jeg skal benytte meg av. Synes vel egentlig at "Guide til" er noe rare greier. Vel jeg skjønner jo at sikkerheten på sikker dybde er godt ivaretatt men men ..... det blir jo mange omveier hvis den følges til prikk og punkter. Er veldig fornøyd med skjermoppløsningen..... plottern er en 525. Kansje det er det som er problemet med din hvis den ikke takler oppdatrerte 3.10 versjonen. Har også lest et sted her på forumet at de hadde et problem med den forrige modellen (420) men at de fikset den uten problemer (Belanor).
Heisann.
Noen som vet om det er mulig å sitte på pc og lage ruter, for så å lagre de på sd-brikke og overføre til plotteren etter på?
Eller er det kun mulig å sitte i båten å lage ruter på/med plotteren..
Halloen!
Det du ønsker deg er noe jeg også virkelig kunne tenkt meg.
Sydvesten har spurt om det samme for en større Garmin modell og fått svar fra Garmin. Se denne tråden, nest siste post.
Jeg synes det er pussig at det ikke er noe software for dette siden man har eksport/import muligheter i selve enheten. Jeg forsøkte å eksportere, men fikk bare en fil på kortet som er binær og er sikkert i et internt Garmin format...
Svart (redigert)
De nye plotterene bruker vandlige SD minnekort, så en minnekortleser kan i prinsippet brukes til å lese fra kortet... Det jeg ønsket var et program som gjør at jeg kan lese kartene på pc'en og ikke koble til gps.... for å kunne kose meg litt med kartet på pc'en i ro og mak og sjekke ut kartdetaljer
Sitat her: https://baatplassen.no/i/index.php?s=&s...st&p=535791
Jepp, det var akkurat det jeg tenkte på og var ute etter.
Videre så har jeg fortsatt problemer med å få lest svaret fra garmin om Fw v3.10 inne på kontoen min på myGarmin siden. Andre her som har konto der og opplever det samme?
Hei.
Hi
Mvh Kenneth
Jeg fikk mail fra garmin nå idag, og:
Dear Kenneth,
Thank you for contacting Garmin(Europe)Ltd.
Thank you for your email, I can't say that I have come across this issue before. Please re-load the version 3.10 software to the device and try again as it might have been a corrupt download of the 3.10 software version. Please try this again and let me know if the issue persists.
Thank you.
Kind regards
Alex ******** Garmin (Europe) Ltd
The Global leader in satellite navigation
Så da blir det samme som deg da Indiana som heller ikke har merket noe feil.
So rock`on with updating v3.10
  • 1 måned senere...
Change History
Changes made from version 3.10 to 4.00:
An SD card with 60MB of free space is needed for this update
* Changed labels for numeric configuration buttons from 'Overlay Numbers' to 'Data Bars' and added more user setup options for Cruising, Navigation, and Sailing data bars.
* Improved the visibility of the map pointer.
* Added a 'Local Services' search feature which finds services near the map pointer of the Navigation and Fishing Overlay Charts.
* Added a distance measurement tool on the Navigation Chart menu.
* Added a control to the waypoint review page for moving a waypoint on the map if it was reviewed via the map.
* Added controls to toggle on and off the display of photo points, service points, land POIs, and Tides/Currents symbols on the Navigation Chart.
* Added control to toggle on and off the display of Navaids on the Fishing Chart.
* Added the ability to show/hide saved tracks and the active track based on color.
* Improved track up map updating so it is more responsive to vessel direction changes.
* Added support for SDHC cards, which have capacities greater than 2GB.
* Changed default sonar background color to blue for all products except Gmap430s, Gmap530s, and Gmap535s.
* Modified to display all AIS targets on the charts by default, and added a menu item to only show the 5 closest AIS targets.
* Dynamically scale fuel rate and fuel economy digital gauges.
* Added G2 Vision Card information to the System Information Page
* Added a 'Route Bar' control under 'Navigation Bar Setup', which toggles the display of additional route specific data.
* Changed arrival alarm to trigger on arrival at 'Destination' or 'Destination and Turns' based on user's preference.
* Added an option to create a route from a list of existing user waypoints.
* Performing a Go To will now draw the desired track lane from the origin to the destination for those who wish to use Go To for following a specific course with minimum cross track error. The lane center line will still 'float' with the vessel for those who wish to navigate by bearing only. Routes can still be used to create navigation lanes with a fixed center line.
* Added Offset Navigation which allows navigation based on a fixed distance from the original route. This is useful for trolling a precise distance from regulatory fishing boundaries.
* Changed route creation on navigation and fishing charts to no longer require selecting 'Add Turn' for the last point if the pointer is moved away from the last 'Add Turn' position. When 'Done' is pressed, the location of the pointer will be the last route waypoint.
* After saving a route created on the navigation or fishing charts, the user will be presented with the route review page so they can easily change the name at that time.
* Added Stop Navigation option to Mariner's Eye menu.
* Added Fish Eye 3D view control to allow fore, aft, port and starboard views. Also added manual panning of Fish Eye 3D.
* Changed Mariner's Eye 3D camera so that it can be positioned to look straight down when zoomed out to the minimum zoom level and extended the view to the horizon while navigating.
* Made vessel turning with 3D pages smoother to eliminate overshoot when steering a route line in 3D.
* Made the auto guidance lane width on the Mariner's Eye 3D page user adjustable.
* Always display review, route creation, and position select maps with north up orientation.
* Added additional digit for Loran TD offsets to allow entering larger offsets.
* Updated the Auckland, Hawaiian, and Eniwetok time zones to the new DST standards.
* Fixed placement of the North arrow on Track up maps. Previously the arrow was inconsistently placed in the upper right or upper left corner.
* Display the total fuel remaining data bar number with a maximum of 4 digits. Previously, the maximum was 3 digits and volumes over 999 would display as invalid.
  • 1 måned senere...
Nå August 28, 2008 kom enda en ny softwareoppdatering til 420/520/525 og S
Det har vært 2 oppdateringer siden sist post, jeg har ikke helt fulgt med i sommer.
Change History
Changes made from version 4.10 to 4.20:
* Added the option to configure the distance from a turn at which the system will transition to the next leg of a route.
* Fixed issue where Mariner's Eye 3D may draw the water surface of a lake well below surrounding land when the scene contains only partial 3D information.
* Fixed issue where a world base map would to be drawn instead of an available supplemental map when viewing an area near that supplemental map's border.
* Fixed issue that may apply a weather warning to an area that is not under a warning in addition to the correct warning area.
* Added support for the Arabic language.
Changes made from version 4.00 to 4.10:
* Added the ability to configure the level of detail shown by the base map.
