mega rart koblingskjema?
Superkul
Hvis du vil lage noe mer avansert med egne endestopper kan du lett gjøre dette med en on-off-on bryter- to 12V relér og to brytere for topp og brunn endepunkt... Da kobler du bryteren som styrestrøm til hvert av reléne- Legger omvendt polaritet gjennom hvert relé. Så legger du endepunkts bryterene slik at de bryter styrestrømen til relét som drar.
Enkelt?
- MartinL
Hei
Her er internettadresse til P6216 :
http://global.ebay.com/gbh/viItem?ItemId=7998654921
Her er de viktigste dataene:
You are looking at a New Universal 16" Power Linear Actuator. Linear actuators are the ultimate accessory for installing power operated hoods, trunks, tonneau covers or any other heavy duty application and are great for custom applications. The 10:1 gear ration offers quick operation even on the most stubborn of lifting jobs. These actuators offer a heavy duty built in clutch to insure against over, and under extension of the main gear. The built in clutch insures your linear actuator a long life of smooth operation, while providing maximum direct power to your lift application. Then lightweight steel actuator case encloses the high torque electric motor and lubricated actuator shaft ensuring maximum performance without hoses or greasy parts. The heavy duty motor features the following:
Built in Potentiometer
Screwdriver Assembly
Can lift up to 250 lbs
16" Travel
10:1 Gear Ratio for Quick Operation
Built in Clutch
High Torque Electric Motor
Permanently Sealed and Lubricated
I have the following Linear Actuator Lengths Available. Please click on the links below. P6216
Med built in clutch kan det vel forståes at det ikke er endestoppbrytere men at motoren slurer i endestilling...
