SmartCraft instrumenter virker ikke
kkjelby
Gratulerer med ny båt.
Er overrasket over at forhandler ikke klarer å få dette til virke.
Noen av de eldre motorene brukte en "junctionbox" hvor alt ble koblet til, nesten som en hjerne.
De nye Mercruiser motoren er rimelig plug & play, da de kommer med SmartCraft tilkobling rett til ECM'en. Hvis kablene er nye, og intrumentene er nye, er det vel bus'en i ECM som ikke virker.
Neste for forhandler må vel være å montere ny ECM, og se hvordan det fungerer.
Fant dette med ett søk her båtplassen:
MASTER RESET
You can return the gauge back to factory presets through the Master
Reset command.
IMPORTANT: Performing a master reset will reset the unit back
to all factory defaults, thus eliminating any installation calibrations
performed during set up of product.
By pressing TROLL
– and TROLL
+ simultaneously for approximately 10
seconds (Until the graphic bars “collide”), you will be able to restore
the unit back to factory presets.
Automatic Engine Detection Feature
The System Tachometer/Speedometer has an automatic engine
detection feature. This feature automatically detects which engine
type is used and configures the gauge to match that engine type.
SYSTEM TACHOMETER/SPEEDOMETER
2
The first power up of the gauge, or after a Master Reset, the gauge
will display "AUTODETECT". Press the "MODE/SELECT" button
to start the automatic engine detection feature and the gauge will
determine the engine type. This will preset the data monitoring
screens to make the initial setup easier.
AUTODETECT
ENGINE SMARTSCREEN
PRESS MODE/SELECT TO START
24298
If the gauge shows a warning of "NO STARBOARD ENGINE" or
"MULTIPLE STARBOARD ENGINES", the engine location (port
and starboard) must be selected by an authorized dealer equipped
with the computer diagnostic system (CDS) tool.
Om du ikke har manualen kan du laste den ned herfra:
http://www.google.no/url?sa=t&source=web&cd=1&ved=0CBgQFjAA&url=http%3A%2F%2Fwww.mercurymarine.com%2F_media%2Fpdfs%2Fprecisionrigging%2Fsmartcraft_manuals%2FSystem_Monitor_Manual.pdf&ei=292PTNvUJIbaOImwrZgK&usg=AFQjCNHFublTJIuywMFfkzMaV7rXKtvDug&sig2=4CTmGsRojYeD7x-o8KgjGw
**ser adeneo, redigerte sitt innlegg mens jeg skrev mitt**
junctionbox`n er bare en grenboks ut fra hovedkabelen som er plugga i ecm`n om man har flere enn ett instrument.
"master resett" er en ting på instrumentene så de skal finne ut hvilken motorstyring det er og så identifisere seg med ecm, og deretter kommunisere/lese motordata fra ecm`n
Redigert av KenBjork (see edit history)
helt sikkert en jordingsfeil eller skadet kabelstokk mellom motorrom og styreposisjon. Har brukt mange timer på feilsøking av disse systemene, men det er heldigvis noen år siden nå. At disse ikke fungerer når båten kommer fra fabrikk er dessverre helt normalt. Vet ikke om systemet er endret på den ny to-litersmotoren, men før var dette et system med rom for mange feilkoblinger og mange båtbyggere koblet dette feil rett som det var. Forhandleren trenger sikkert bare litt tid på å finne ut av dette så ordner det seg. Gratulerer med ny båt!
Har nå ved selvsyn sett hva som skjer.Ved power up av instrumenter, så vises smartcraft versj. Etc. Motor startes. Visereren på turtelleren er død. ingen oljetrykk, ingen indikasjon på lading 0 volt og 0 psi. Eneste som kommer opp er check engine. ECM er byttet jording sjekket. Trim og fuel er ok. Har tatt master reset på instrumene.
Kan kabel mellom motor og VIP være u/s?
Lurer på om det er noen her som har hatt lignende problemer.
skulle likt å visst hvilken forhandler du har kjøpt av. Dersom båten din er ny skal denne ha vært testet hos marinepowers klargjøring og monterings partner, dette er en tjeneste de kjøper nettop for å slippe uhell sånn som med din båt. dersom instrumenter er byttet og ecm enheten er skiftet er det bare hovedkabelen igjen, de bruker ikke lang tid på et prov opplegg bare for å utelukke. Tror jeg ville forsøkt å heve kjøpet evt. fått levert en annen tilsvarende model. LYKKE TIL skal du i hvertfall ha.
Erik
