Hvor bestiller eg tenningsdeler til VP 250A
Sjeldenutpå
Hvis du har lest riktig, og dette er en VP 250, så er det samme motoren som AQ151, altså en firesylindret Volvo motor.
Dersom du har lest feil, og det er en 200, 225, 260 osv. så er det en V8'er, men det bør være mulig å se forskjell på en rekkefirer og en V8'er ?
General
Type designation ................................................................................. 250, AQ151
Type of engine ..................................................................................... 4 stroke, overhead cam
Speed range full load ........................................................................... 80–91.7 r/s (4800–5500 rpm)
Maximum cruising speed .................................................................... 3.33 r/s (200 rpm) lower than the max speed obtained
Compression ratio ............................................................................... 9.7:1
Compression pressure at starter motor speed1) .................................. 10–12 kp/cm2 (142–170 psi)
Number of cylinders ............................................................................ 4 in line
Bore ..................................................................................................... 96 mm (3.7795")
Stroke .................................................................................................. 86 mm (3.3858")
Swept volume (displacement) ............................................................. 2.49 dm3 (151.9 in3)
Weight, excluding water and oil, approx. ............................................. 250 Kilos (551.2 lbs)
Idling speed ......................................................................................... 15 r/s (900 rpm)
Tenning
Basic setting ........................................................................................ 6° BTDC (0–14.17 r/s = 0–850 rpm)
Stroboscope setting ............................................................................ 32–36° BTDC (70 r/s = 4200 rpm)
Contact gap ......................................................................................... 0.40 mm (0.01575")
Dwell angle .......................................................................................... 62±3°
Skifte av delene er beskrevet i manualen !
Og kvalitetsdeler får du hos Volvo Penta til følgende priser :
Stift: 83,75,-
Rotor : 85,-
Kondensator : 107,50,-
Fordelerlokk : 715,-
Plugger og ledninger ville jeg anbefale å kjøpe NGK BP6ES plugger (eller hva som står i listene for Volvo B230 motor) og et bra sett med pluggledninger hos nærmeste bildelesjappe, og der får du sikkert også stift, rotor osv. billigere enn hos VP.
Nja, nå spør du vanskelig?
Jeg har kun kjøpt deler til fordeleren hos VP, og det sitter normalt en annen gnistsikker fordeler på båtmotorene, men om det innvendig er helt likt som på bil vet jeg ikke, men noe av det er sikkert det?
Jeg ville vel uansett kjøpt tenningsdeler hos VP, og som nevnt NGK plugger og noen skikkelige tennkabler på en bildelesjappe, eventuelt vurdert 123 ignition hvis man vil legge noe mer i det.
