Jakob T Posted April 14, 2014 Share Posted April 14, 2014 Har fått feilkode 2.2.Har nett skiftet turboer og givere til røykbegrenser.Etter endt prøvetur blei det skiftet dieselfilter.Motor vart starta med nesten fult filter,gikk på tomgang i 5 min før den stoppa.Feilkoden ligger i displayet,prøvd å legge den strømløs,men stoppkoden kommer igjen.Noken som veit å resette EVC Quote Link to post Share on other sites More sharing options...
Joda3300 Posted April 14, 2014 Share Posted April 14, 2014 Code 2.2 Injection pump A/B/CReason: Short circuit/open circuit in signal from control sleeve position sensor. Reaction: The engine is stopped. Action:• Check connections on injection pump and control module.• Erase fault code.• Start the engine.• If the fault remains: Check the position sensor function (please refer to the “Electrical fault finding”chapter). Position sensor (17)The position sensor provides the control module withinformation about the position of the control sleeve,which corresponds to the amount of fuel which is currentlybeing injected. KA(M)D44P-C and KA(M)D300-AThe fault code memory in the diagnostic function is“erased” every time system voltage to the engine isshut off. NOTE! The system voltage must be completely cutoff. Stop the engine and check that the ignition key(s)is(are) in position 0 in all control positions.When system voltage is switched on again, the diagnosticfunction checks to see whether there are anyfaults in the EDC system. If this is the case, new faultcodes are set. This means that:1. Fault codes for malfunctions which have been attendedto or which have disappeared are automaticallyerased by cutting off system voltage andswitching on again.2. Fault codes for malfunctions which have not beenattended to must be acknowledged every time thesystem voltage is switched on. Håper noe av dette kan hjelpe deg på problemet videre Mvh Tom Erik Quote Link to post Share on other sites More sharing options...
Jakob T Posted April 14, 2014 Author Share Posted April 14, 2014 Takker for svar.Får prøve å måle i morgen.Håpløst med all den elektronikken. mvhJakob Quote Link to post Share on other sites More sharing options...
Jakob T Posted April 15, 2014 Author Share Posted April 15, 2014 Etter ei hygglig samtale med Tom Erik,vart det diskutert forskjellige løysninger.Det vart foreslått å bytte EDC bokser,da dette er ein twin instalasjon,for å prøve å starte den med feil,for så å bytte tilbake for å sjå om feilkoden blei sletta.Motoren med feilkoden starta med den andre EDCn,men starta ikkje når den vart satt tilbake. Der ser ut som EDC boksen er defekt,å må skiftes .Dette er ein kostbar del,som det ikkje er mulig å reparere,er vel bare å bestille ny.Greit å få tips og hjelp gjennom dette forumet.og Bjordal og Madsen Quote Link to post Share on other sites More sharing options...
Joda3300 Posted April 15, 2014 Share Posted April 15, 2014 Hyggelig at vi fant ut av det ;) kjipt at det var EDC`n, men sånn er det noen ganger.. Mvh Tom Erik Quote Link to post Share on other sites More sharing options...
Cava Posted June 24, 2021 Share Posted June 24, 2021 Hadde akk samme feil på min, viste seg å være irr på kontakt til EDC, sjekk dette alle sammen. Quote Link to post Share on other sites More sharing options...
Join the conversation
