Ubåtssimulator
Gunga Din
SUGGESTIONS FOR THE FORMER DIESEL/ELECTRIC SUBMARINER WHO MISSES "THE GOOD OLD DAYS ON THE BOATS."
1. Invite 80 people you don't really like to come and visit for a couple months. Don't have enough food for them. Limit showers to weekly for all guests.
2. Spend as much time as possible indoors and avoid sunlight. Only view the world through the peep hole on your front door.
3. Sleep on the shelf in your closet. Two to three hours after you fall asleep, have your wife shine a flashlight in your eyes, and mumble, "Sorry, wrong rack."
4. Renovate your bathroom. Build a wall across the middle of your bathtub and move the shower head down to chest level. Shower once a week. Use no more than 2 gallons of water per shower.
5. Buy a trash compactor and use it once a week. Store garbage in the other side of your bathtub.
6. Paint the windshield on your car black. Make your wife stand up through the sunroof and give directions on where to drive. Drive through as many big puddles as possible.
7. Leave lawnmower running in your living room six hours a day for proper noise level.
8. Replace all doorways with windows so that you have to step up AND duck down to go through them.
9. Put lube oil in your humidifier instead of water and set it to "High."
10. Buy bunk beds (4-high type) and convert the narrowest hallway in your home to a bedroom.
11. Hook up your air compressor to the sewer line to the house and blow a shit geyser ten feet in the air. Come inside and tell your wife 'calmly,' "I forgot to shut the valve." Then, make her and the kids clean up the mess.
12. Change the plumbing under your house so that the sewer line is vented inside your home.
13. Every so often, yell "Emergency Dive," run into the kitchen and sweep all pots/pans/dishes off of the counter onto the floor. Then, yell at your wife for not having the place "stowed for sea."
14. Take the jack handle out of your car's trunk and install it in the ceiling over your stove. Several times a day, give it 112 turns and yell, "Main induction secured."
15. Practice walking quickly with your back to the wall.
16. While doing laundry, replace liquid fabric softener with diesel fuel.
17. Fill laundry tub with oil. Lay in it, on your back, and change the washers in the water faucets.
18. Take hourly readings on your electric and water meters.
19. Cut a hole in the floor of your house and install some batteries. Go down there once a day and take specific gravities.
20. Put on the headphones from your stereo (don't plug them in). Go and stand in front of your stove. Say (to nobody in particular) "Stove manned and ready." Stand there for 3 or 4 hours. Say (once again to nobody in particular) "Stove secured." Roll up the headphone cord and put them away.
21. Give your wife more free time. All of the ironing goes under the mattress.
22. Tag out the steering wheel, gas pedal, brake pedal, transmission and cigarette lighter when you change the oil in your car.
23. At night, replace all lightbulbs in the living room with red bulbs.
24. Repeat back everything anyone says to you.
25. Sit in your car for six hours a day with your hands on the wheel and the engine running, but don't go anywhere. Install about 200 extra oil temperature gages. Take logs on all gages and indicators every 30 minutes.
26. Lockwire the lugnuts on your car.
27. Watch only unknown movies with no major stars on TV, and then only at night. Have your family vote on which movie to watch, then watch a different one.
28. Have the paper boy give you a haircut.
29. Make up your family menu a week ahead of time without looking in your food cabinets or refrigerator.
30. Buy all food in cases and line the floor with them.
31. Eat only food that you get out of a can or have to add water to.
32. Wake up every night at midnight and have a peanut butter and jelly sandwich on stale bread. (Optional -- cold beans and weenies, canned ravioli or soup).
33. Store your eggs in your garage for two months and then scramble a dozen each morning.
34. Use 18 scoops of coffee per pot and allow it to sit for 5 or 6 hours before drinking. Never wash any coffee cups.
35. When making cakes, prop up one side of the pan while it is baking. Then spread icing really thick on one side to level off the top.
36. Raise hell with your wife when she serves steak the next time. When she says that that's the way it came from the store, you ask, "BURNT?"
37. Go to the market and buy 100 quarts of milk. Pour them into a large white trash bag and secure. Put the bag in the refrigerator and rename it: "The Cow."
38. Use Kool Aid on your breakfast cereal for two months.
39. Just have someone chew your ass out over nothing, daily.
40. To duplicate normal in-port routine, hire about 20 drunks to come into your house about one in the morning and start cooking.
S/Y Gunga Din
Fikk komme på brua på hurtigruta i vinter, 'nattes tid' (det vil si når som helst på døgnet untatt mellom 11.00-13.00 nordpå.) Der var det dus rød belysning, og SVÆRT strengt forbud mot bruk av lys (eks tenne seg en røyk med lighter). Dette var pga nattesynet.  Da jeg kom inn på brua så jeg ikke en skitt, men etter få minutter så jeg klart og tydelig, og samtidig hadde vi 'god' sikt ut.  Så det har nok sin misjon, men på en ubåt er det vel ikke så mye 'utsikt' kanskje  :smiley:
Erik.
