Seilbåtnyheter
Kosmix
Jeg har ingen erfaring med seilbåt - med bærer på en hemmelig drøm om en gang å bli eier av en
Personlig synes jeg de nye seilbåtene med sin rette baug og avkutta hekk blir mindre og mindre tiltalende. Men det har sikkert sine fordeler.
Men hvor blir det av de feminine smekkre linjene :nonod:
Vell - nå er jo jeg en håpløs nostalgiker - så jeg får vel bare holde kjeft :smiley:
Heller mot det samme.
de gamle båtene er penest og vakkrest. :smash:
men noen liker mora, mens andre syns den ungre dattera er penest. :yesnod:
Vi er bare slik.
Det eneste du vil angre på at du har gjort, er alt det du ikke gjorde. "Do it to day."
Medlem av: Ankerdrammens Venner. OCC,ESF, & SYC.
http://lagoon380careka.blogspot.com/
Dear Sailors,
we are please to inform you that the new Finn Flyer 36 Club made its debute at the Helsinki floating boatshow last weekend.
According to many visitors it was the Top Boat of the Show! Feel free to make your own judgement.
Finn Flyer 36 Club is a dual purpose designed boat , that provides fast and fun sailing on deck and luxury living below deck.
Due to the advanced composite construction technique the yacht performs as a Racer though equipped with a cosy and comfortable
wooden interior look.
The first boat weighed only 5130kg with teak deck and cruising equipment !
For more information and test sailing in Helsinki please get into contact.
Best regards Lars Sjöman
Finn Flyer Sales
www.finnflyer.com
Club er regatta versjonen
Finn Flyer 36 Club is the racer in the Finn Flyer 36-family differing from
the cruiser-racer by beeing fitted with a deeper T-keel. The yacht is primarily
designed and equipped for performance. It is the ideal yacht for the
competitive sailor looking for a comfortable interior without sacrificing
performance. In terms of raw speed the boat is designed to match
pure racers. The design enables good performance in ORC international
and IRC.
Finn Flyer 36 CR is a modern high performance cruiser-racer. The hull is made with
the injection method and composite parts are used for the interior to ensure that
the boat is light and stiff with a high ballast ratio. A generous rig with
non-overlapping sails guarantees performance both on and off the wind.
Finn Flyer 36 CR is the ideal boat for the performance-minded sailor who
wants to be able to combine long offshore passages and competitive racing.
The modern and beautiful hull lines provide ample interior with standing height
in the saloon and head. Up to 7 bunks can be fitted with sufficient storage.
Redigert av Enzo (see edit history)
Sprek båt,antagelig stort fartsptensiale.og gedigen seilglede :sailing:
Kommer det noen skeptiske komentarer her tro,vedr.størrelse på anleggsflate kjøl,etc?Hva jeg kan se av tegninger/bilder/brosjyre,ville nok antagelig konsekvensene ved landkjenning i 5-6knop og bråstopp med denne båten være større enn ved de fleste andre båter som er nevnt 100 ganger hr på forumet. :confused:
mvh
fem@il
Jeg har faktisk studert bildene på hjemmeside ut og inn i sikkert et år, men tenkte ikke over at det var clubversjonen pga den massive innredningen og teakdekket....men åpen hekk og T-kjøl burde gitt meg et hint.
Denne har stått høyt oppe på drømmebåt-lista, og etter å ha sett bildene er den enda høyere oppe...
:cheers:
Seilerhilsen fra Kosmix!
Logg og blogg: x79.blogspot.com
Twitter: Følg meg her!
