Skipper Worse Startet 29.August.2009 Link til dette innlegget Startet 29.August.2009 (redigert) 3300 Nm dreiemoment -- det hadde vært noe, det. The new D13-900 - Volvo Penta's most powerful ever For almost a decade, the Volvo Penta D12 has been the leading engine for motor yachts in the 50-foot class. Volvo Penta is now introducing its new, more powerful, more fuel-efficient and cleaner successor: the Volvo Penta D13. With its 900 horsepower, it is Volvo Penta's most powerful engine so far for leisure boats. A characteristic of Volvo Penta's inboard diesels is their high torque from low rpm. A crucial property for rapid and safe acceleration. The new D13-900 is equipped with new dual-stage turbo technology. The first stage is a twin entry turbo with pulse charging - the power in each exhaust pulse is used to provide pulse pressure - which results in a very high torque from low rpm. At higher rpm, a second turbo kicks in so that the engine retains its power even at high rpm. The D13-900 reaches its maximum torque of 3300 Nm at only 1300 rpm/min - a uniquely high torque for this class of engine. The engine also retains a very high torque throughout its speed range, an important factor when the boat is heavily loaded. Low fuel consumption, minimum emissions Highly efficient combustion is a prerequisite of low fuel consumption and low emissions. EMS 2, the engine control system developed by Volvo Penta, regulates fuel injection 100 times per second, twice as often as the previous version. The system controls the unit injectors, one per cylinder, which operate at a pressure of as much as 2000 bar and atomize the fuel for optimum combustion. The result of this efficient combustion is lower fuel consumption - 10 percent lower for the D13 than the D12 at the same power output. Exhaust emissions are also lower than ever before. Acceleration smoke levels at all rpm are well below the visible level. Total emissions satisfy by a wide margin the EU RCD and US EPA Tier 2 regulations and are also in line with the very stringent EPA Tier 3 regulations that will come into force in 2012. Quick shift and low speed The D13 is available with "Quick Shift" reverse gears - an advanced technology that provides very fast but soft shifting with a minimum delay. The reverse gear also comes with a low-speed function as standard, which means that the speed when idling drops from about six knots to three knots. A very important aid when maneuvering or fishing. Electronically integrated The new D13 is equipped with EVC, Volvo Penta's electronic platform, which includes electronic shift and throttle all the way from the controls to the engine and drive. EVC also makes it simple to install additional accessories and functions such as a trip computer, engine data in the chart plotter via NMEA or the new 7" color display. With EVC, it is possible to have instrumentation, or complete helm stations, in up to four locations on board. Technical data Model designation: D13-900 Configuration: In-line 6-cylinder diesel with dual-stage turbo, twin charge air coolers and electronically controlled unit injectors Cylinder volume: 12.78 liters Max. torque: 3300 Nm (2438 lbf.ft) at 1300 rpm Max. power: 900 hp (662 kW) at 2300 rpm Emissions: Satisfies EU RCD and US EPA Tier 2. Prepared for EPA Tier 3 to be introduced in 2012. www.volvopenta.com August 2009 Redigert 29.August.2009 av Skipper Worse (see edit history) Sitér dette innlegget I've always been crazy, it has kept me from going insane. www.baatjuss.no | www.judiciumblawg.no Link to post
Penny Svart 30.August.2009 Link til dette innlegget Svart 30.August.2009 Mye felles deler med nyeste Volvo FM/FH lastebilmotor på samme volum? Nokså voldsomt å tilby 70 % høyere effekt enn på kraftigste versjon for lastebil. Maks effekt hevet med 400 rpm i forhold til lastebilmotoren, er det økt kjølekapasitet når motoren står i båt som tillater en slik endring? Sitér dette innlegget Link to post
kjukken Svart 30.August.2009 Link til dette innlegget Svart 30.August.2009 Burde være omvendt, spør du meg (men det er det ingen som gjør). Båtmotorer kjører bestandig i motbakke. Det er det ingen bil- eller lastebilmotorer som gjør. Sitér dette innlegget Link to post
Brynjar Svart 30.August.2009 Link til dette innlegget Svart 30.August.2009 ..men "tåler" den norsk båtdiesel? Sitér dette innlegget . . bmhe Link to post
nomen Svart 30.August.2009 Link til dette innlegget Svart 30.August.2009 Båtmotorer kjører bestandig i motbakke. Det er det ingen bil- eller lastebilmotorer som gjør. Det er netopp det som er fordelen,motoren blir utsatt for en jevn belastning,ikke rykk og napp og ikke motorbrems. Den står i et rom med nokså jevn temperetur,og får også all den kjøling den vil ha. Dette er viktige faktorer som spiller inn. Så vidt jeg vet er ikke båtmotorer underlagt like strenge krav til utslipp,noe som gjør at det kan hentes mer ut av motoren. En tredje ting er at det er ikke motoren,men drivverket som setter begrensninger i forholt til spesielt dreimoment. Girkasser og drivaksler blir utsatt for enorme påkjenninger etter spesielt norske landeveger,i båt blir det annerledes. Derfor kan en hente mer effekt ut av samme motoren,kan nevne at for 6-8 år siden hadde 16 liters motoren til Volvo 520 HK når den stod i lastebil,og 1000 HK når den stod i aggregat- Sitér dette innlegget Hold kjeft,når du snakker til meg! Link to post
bellen Svart 30.August.2009 Link til dette innlegget Svart 30.August.2009 Så vidt jeg vet er ikke båtmotorer underlagt like strenge krav til utslipp,noe som gjør at det kan hentes mer ut av motoren. Så vidt eg veit, så er det strengere utslippskrav for ein båtmotor Sitér dette innlegget Link to post
nomen Svart 30.August.2009 Link til dette innlegget Svart 30.August.2009 Om kravene er strengere til båtmotorer enn andre, da er det vel krav til Adblue også da? Tungvint å drasse på dette i båten,eller er det noe en kan forvente å få på de fleste marinaer? Eller har VP løste dette problemet på annet vis? Sitér dette innlegget Hold kjeft,når du snakker til meg! Link to post
Brynjar Svart 30.August.2009 Link til dette innlegget Svart 30.August.2009 Har en 333hk Mercedes på jobb som bruker adBlue. Dette systemet gikk i stå før forrige eu-kontroll så jeg fikk tatt en uavhengig avgassmåling - uten AdBlue. Den gikk da godt under kravene på avgassmålingen... Kan Mercedes levere motorer som går rent uten AdBlue, så kan sikkert Volvo også Sitér dette innlegget . . bmhe Link to post
nomen Svart 30.August.2009 Link til dette innlegget Svart 30.August.2009 Grunnen til at du "greide" avgasstesten er fordi en slik test måler partikkeltettheten i eksosen,det heter jo røykgassmåling. Adblue fjerner NoX gasser fra eksosen,dette blir ikke målt ved EU-kontroll.(gjorde ikke det for 4 år siden ihvertfall) Det er mulig og ikke bruke Adblue for å klare avgasskravene,men da er det andre systemer som gjør dette. At det er strengere krav til utslipp på fritidsbåter enn på lastebiler var helt nytt for meg. Sitér dette innlegget Hold kjeft,når du snakker til meg! Link to post
