En merkelig epost ang. båtkjøp
Platt
Ovenfornevnte er et meget godt poeng !!!!
Det har forekommet tidligere (ref. Økokrim), at sjekker er sendt, og man har vært sikker at pengene er i orden, men i bankverdenen er der fremdeles slik at ting tar tid, mtp sjekking.
For all del, utelukk all kontakt med slike tilbydere fra det fjerne. Svindel foregår på mer og mer snedig måte og det er i hvert fall illeluktene når de kjøper en båt som har høyere fraktkostnader enn selve båten............
Scam! Scam! Scam!
They send you a fraudulent bank draft for an amount much greater than the price of the item for sale and ask you to forward the remaining amount to a third party. You even get to keep some of the money for your troubles. A few weeks later the bank jumps on you for submitting a false check.
So many people have been taken by this... blinded by greed and naivety. Keep away!.
PiperBill
And always remember the wire should have a higher rating than the fuse as otherwise the wire becomes the fuse!
Lasse:
Return-path: <frankmetu03@box.az>
Envelope-to: frank@tostrup.com
Delivery-date: Sat, 23 Oct 2004 11:38:07 -0700
Received: from [216.55.169.4] (helo=mail.box.az)
     by mx.mailix.net with smtp (Exim 4.24-CT)
     id 1CLQmB-0007KR-HU
     for frank@tostrup.com; Sat, 23 Oct 2004 11:38:03 -0700
Received: (qmail 30552 invoked by uid 65534); 23 Oct 2004 23:38:02 +0500
Date: 23 Oct 2004 23:38:02 +0500
Message-ID: <20041023183802.30551.qmail@mail.box.az>
To: frank@tostrup.com
X-Mailer: Box.az WebMailer
X-Mailer-Version: 1.12.0
X-OriginatingIP: 82.206.246.122
X-Sender: frankmetu03@box.az
MIME-Version: 1.0
X-SA-Exim-Connect-IP: 216.55.169.4
X-SA-Exim-Mail-From: frankmetu03@box.az
Subject: URGENT BOAT PURCHASE.
Content-Type: text/plain; charset="utf-8"
X-Spam-Checker-Version: SpamAssassin 3.0.0 (2004-09-13) on
     westvirginia.backend
X-Spam-Status: No, score=0.9 required=10.0 tests=FORGED_RCVD_HELO,
     FROM_ENDS_IN_NUMS,SUBJ_ALL_CAPS autolearn=no version=3.0.0
X-Spam-Level:
X-SA-Exim-Version: 3.1 (built Thu Oct 23 13:26:47 PDT 2003)
X-SA-Exim-Scanned: Yes
Received-SPF: none (spfquery: domain of frankmetu03@box.az does not designate permitted sender hosts) client-ip=216.55.169.4; envelope-from=frankmetu03@box.az; helo=;
X-uvscan-result: clean (1CLQmB-0007KR-HU)
X-NAS-Bayes: #0: 1.90695E-015; #1: 1
X-NAS-Classification: 0
X-NAS-MessageID: 19464
X-NAS-Validation: {91488D5B-5E46-4AB2-8021-7FA62446D91C}
Hello,
This is Mr Frank Metu  from Pretoria south africa. I am intrested in buying your (1975 MotorbÃ¥t Fin dagstur/landstedbÃ¥t)  for 150,000.00 NOK
in respect of shipping to Pretoria, Republic Of South Africa my shipping Agent in london will take care of shipping. I have already contacted a client owing me the sum #20,000.00pounds and he has agreed to send a check or money order and bank draft to you. As soon as it clears your bank, please deduct the cost and you can send the balance via western union money  transfer to my shipper.Also send the boat pic If this is okay, Please forward Name Address Telephone Zip Code so that I can arrange payment.
Thanks
Frank Metu..
Få høre hva du får ut av denne , da?
Slett mailene og glem det hele. Du har jo fått oppskriften på hva som vil skje i postingene over. Når jeg har forstått at båten er 17' og averteres for 15.000 er det jo enda mer opplagt at dette er svindel. Og hvorfor kjøpe noe sånt på motsatt side av kloden, når du i tillegg ikke oppholder deg i det landet du sier du kommer fra?
Og den nye vrien med en sjekk som ikke blir godkjent var jo smart. Tidligere varianter jeg kjenner til har forutsatt at du lar deg lure til å betale forskudd for å dekke "kostnader".
Her blinker det ikke bare røde lys......
Tenk også på at du, i tillegg til å tape masse penger også kan komme i en situasjon hvor du selv blir strafferettslig ansvarlig.
Hilsen KOB, Nimbus Nova 35
(men setter de inn dette beløpet inn  på din konto??)
Ja, slik jeg forstår gjør iallfall amerikanske banker det.
Men tar altså ikke noe ansvar når det oppdages at dekning mangler.
Utrolig utspekulert det hele.
Men som Paperbill sa: "blinded by greed and naivety".
At svindlerne lykkes skyldes ikke bare at de selv er grådige, folk som lar seg lure på denne måten bør kanskje gå litt i seg selv også....  :rolleyes:
Det kan sikkert ikke gjentaes for ofte, er noe for godt til å være sant så STAY AWAY!.... :smiley:
Bra at FrankA tok opp dette siden de nå tydligvis også prøver seg på det norske båtmarkedet.
Skal legge en link til denne tråden under Kjøp/salg i dokumentarkivet...
Var i CapeTown for et par år siden. Snakket med en nederlender som hadde kjøpt seg en 40 fots seilbåt som han skulle seile til Australia. Denne hadde han gitt 400k NOK for. Det dobbelt av hva han hadde gitt for den gamle 27 foteren hjemme. Har ikke sjekket noen båtpriser der nede, men han sa det var latterlig billig. De har enten man liker det eller ikke, veldig mye billig arbeidskraft, så båten hadde vært i topp stand. (Jeg fikk aldri sett båten).
Utfra det han sa høres det rart ut å kjøpe båt i Norge.
Vi behøver kanskje ikke å dra denne så mye lenger, men tenkte bare å nevne at jeg sendte en svarmail, hvor jeg stilte spørsmålstegn ved at vedkommende ikke var mer opptatt av info om båten og kontrakter/formaliteter før han skulle sende en sjekk til en helt ukjent.
Poenget er at disse menneskene ikke gir seg så lett , enda han sikkert har skjønt at jeg ikke er av den lettlurte typen!
Fikk dette svaret:
Hello Frank,
 Thanks for the mail.I will instruct my client who woing me to send the cheque to you and concering the shipping my shipping agent in uk will handle the shippment of the boat.One thing i will let you understand is that i used to buy boat from Europe for the past five years now so dont let this look strange to you okay.Send me your full name address that will be on the cheque so that i will instruct my client to issue the cheque out for the payment of the boat.After that you will prepare export paper for the boat and rest documents for the boat.
Thanks
Frank.
Uansett er denne saken avsluttet for min del. Får heller satse på en kjøper i gamlelandet!  :smiley:
Fikk en litt underlig mail idag fra en kar som tydeligvis er interessert i å kjøpe båten min........Er dette lureri eller??? Har noen vært borti det samme? Dette høres jo helt bort i natta ut!
Hold deg vekke fra denne.!!!!!..   en svindel som har gjort runden i Statene og Europa ... Han vil kjøpe båten din og sender deg en tilsynelatende OK sjekk (som tar tre - fire uker å sjekke) for et beløp som er mer enn du forlanger... Og du skal sende en sjekk til en "venn / bekjent" av ham for det som han betaler "mer" enn forlangende.. Du mister din sjekk, hans sjekk er falsk og du sitter igjen med tom bank konto og i verste fall uten båt!!!!
:nonod:Kort og godt forsøk på SVINDEL. Jeg mottar ulike tilbud / forespørsler hver uke fra Nigeria, Sør Afrika, Hong Kong, etc. Dersom du vil ha det litt moro kan du svare vedkommende via en opprettet mailadresse og kjøre han opp i et hjørne. Alternativt kan du bare slette hele greia og glemme saken.
Svindlerene forsøker hele tiden nye veier...
vidunderkurer mot 'tub-tæring-og-brokk'  :headbang:
Har ikke akkurat behov for det, men jeg begynner jo å dra på årene. Så, - har du fått noen gode tilbud når det gjelder prostata? Ikke det at jeg har merket noe, men broderen som er 3 år yngre fikk problemer for to år siden!  :lol: :lol: :lol: :lol:
Kanskje jeg har gått glipp av noe pga. spam-filterne mine? Fikk jo tidligere så mye tilbud om Viagra at skulle jeg tygd i meg alt måtte jeg gått rundt med en kabeltrommel til å ha snurrebassen oppkveilet på!  :cool: :cool:
Lars H.
Ikke glemm å informere Økokrim da, slik at di kan event. være føre var
:seeya:
Fikk dette svaret:
Hello Frank,
Thanks
Frank.
Samme fremgangsmåte her Poseidon. Drysser inn all verdens dritt, men mye av disse blir nå sortert ut automatisk via Norton Spam filter.
mvh
GipsyGirl
Her hos meg har jeg satt opp det K9-filteret som tidligere ble omtalt her på baatplassen og rost i høye toner.
Når det får "kjørt seg inn", med litt hjelp til whitelist og blacklist så har det en treffsikkerhet på 99,4%   -   og det er etter min forstand.
Derfor skriver jeg med glede under på de anbefalingene som man gav herfra.
mvh
Poseidon
Med vennlig hilsen POSEIDON
Er nok ikke tilfeldig at fyren vil betale 150.000 for en båt til 15.000,-.
Her skal det se ut som om han har lest feil pris og dette vil vekke din grådighet. Tenk, - en godfjott fra S.A. leser feil pris, da kan han ha det så godt.
Men denne gutten vet akkurat hva han gir seg ut på, det kan du rolig gå ut ifra. Han har sikker prøvt ut "konseptet" utallige ganger, med stort hell :lol:.
At en og annen lukter lunta (som du i dette tilfellet), det er en del av gamet. Han har mange jern i ilden og han kan sikkert mange varianter av dette spillet.
"Han" forresten? Her står det sikkert en vel organisert gjeng bak.
Søkte litt på nettet i forrige uke etter å ha fått et av de beryktede Nigeria-brevene per mail.
Dog i en ny utgave fra Nederland. På nettsted som omhandlet denslags ble også bilselgere advart mot henvendelser fra Afrika. Disse ble da beskrevet  med  "shippinghjelp" fra europa. Etter kontakt har visst disse en tendens til å bli relativt truende. De har visst da noen finurlige måter å svindle folk på enten direkte i forhold til produktet som skal selges, men også idet de "trenger" personlige opplysninger, kopi av ID og et kontonummer "de skal overføre penger til".
Tror nok du har kommet ut for svindelforsøk her! Skygg unna!!!!
AASS for OSS! Drikk Aass og piss Ringnes!
Drikk aldri vann (og spis ikke den gule snøen)!!
Hvis du har ork til å forfølge en mobbing a la Scamjokepage kan du få det moro. Jeg har tatt vare på alle de svindel-mailene jeg har fått, og nærmer meg 300.
En dag jeg ikke har så mye å gjøre, kunne jeg tenke meg å lage en terningkast-side på de forskjellige forsøkene. Noen er nemlig ganske imponerende, mens andre er riktig dårlige. Jobben blir bare å finne de forskjellige kategoriene å gi poeng i!
Men jeg vil aldri selge en båt (eller en blyant) til noen av disse gutta. Det som er for godt til å være sant er som regel det.
- ...og når solkula går ned i havet, skal jeg sitte og se utover horisonten og få sjelen i vater! Triztan Vindtorn
