Stell av seil
Krapyl
Normalt skylles seil rene for saltvann og tørkes skikkelig før de legges bort for vinteren. Det kan være fornuftig å skylle seilene i løpet av sesongen enten med slange eller en seiltur i regnvær, men sørg for at de for muligheten til å tørke.
Såpevann er normalt ikke nødvendig, men her er en link som sier noen om behandling av seil med jordslag og hvordan en unngår dette.
http://nsweb.itinfo.dk/no/sailcare.asp
MVH Tore
Cleaning
There are several methods of keeping your sails clean, which are dependent upon the nature of the stain. These methods include:
For dirt or caked-on salt - Remove with a mild detergent and a soft-bristled brush. Avoid harsh detergents and stiff brushes.
For oil, grease, tar and wax - Remove with warm water and soap. For hard stains, a household bleach or M.E.K. can be used on Dacron sails. Do not use bleach on nylon or kevlar sails.
For blood stains - Soak stained portion in a solution of 10 parts water to one part bleach. Scrub and rinse with fresh water.
For rust and metallic stains - Scrub with soap and water, and then apply acetone. Rinse thoroughly with fresh water.
For mildew - Scrub sail with hot, soapy water. For hard mildew stains, use X-14 or a solution of three parts water to one part bleach. Rinse thoroughly with fresh water.
For paint and varnish - Remove with acetone or alcohol.
