Projekt: Scand 9200
doctordre
  • 1 måned senere...
Really nice boat. Impressed!!
What happened with the engines? Still work in progress?
Engine work is stopped at the moment. I just don't have enough room.
I try to finish the trailer as soon as possible, so i can get the other boat  (Donzi 3250) out of the water.
the drives and engine(Volvo)  goes from the Donzi into the scand.
And the mercruisers goes into the donzi.
Both boats win. the Donzi will have semi Original engine and drives. And the gearratio will go from 1.95 to1.5 also, so the donzi will go faster.
And Volvo's are more commonly used in the scand.
The scand will be slower  because of this ratio, but the engine's have a CANBUS driven electronic injection system. so i can connect them to my network system.
For me there´s three things that makes this one stand out:
1: The colour! I´ve never seen an all-blue 9200 before and I think it looks very good!
2: The upholstery. You´ve done a great job making the boat look as good in the cockpit as it does just looking at the whole boat. Looking at the total package you´d never now that the 9200 is actually a pretty ancient design!
3: The engineering. I´m an engineer myself (working with radars) and I absolutely love the dashboard/instrumentation and the electronics behind it. It pretty much makes every brand new boat look slightly obsolete.
I am also a huge fan of the general workmanship and the amount of work you´ve put into all the technical solutions, wiring and all those things that take so much time to do, but once all the panels are in place and hatches are closed, no one will really see. Even brand new boats often have quite shoddy workmanship "behind the scenes", so seeing an old boat brought up to this standard makes the engineer in me very happy indeed! :thumbsup:
Redigert av Kenneth (KAH81) (see edit history)
thank you very much Kenneth.
indeed some brands have shoddy work behind the panels. and usually its the wiring.
But if you see the workmanship of the people on the forum. and some amazing wood work
I wonder what would be the result if they would make a boat together. would be a masterpiece :smiley:
-This boat was not even my first choice, because of the colour.   But together with the teak deck it looks good. I have never seen it somewhere else with scand.
-the upholstery is an idea I got  from classic cars. the colour combination took a while. because brown and blue are difficult to combine.
-indeed when the hatch is closed, the result is hidden behind the panels.
  I am still thinking about a radar.
since recent I work solely with sonar equipment.
  • 2 måneder senere...
the new trailer is ready.
9,5 meters long and can carry a load of 7500Kg
bilde
Since the weather is terrible it gave the opportunity to check how the new tent was doing.
A heavy storm  has passed and the fierce wind blew a piece of the tent out of its rail.
So made the kadors thicker in the corners and the end pieces of the rail. that solved the problem when the second storm went by
And sealing the crack between the targa bar and the boat. water came through.
But worse were the air vent on the sides. With very heavy rain and wind, so much water came in that the waterhole at the end could not cope and
the rest went into the eginebay.
Redigert av doctordre (see edit history)
  • 3 uker senere...
The engine are out. Just little things to check like the condition of the hoses and add a connector for the dashboard.
bilde
Also the Volvo drives are as good as new.
bilde
Now I am looking for spare parts. In general these drives are for diesel engines. The Bullhorns are also for a diesel. now I am looking for the bullhorn for an 8.1 liter.
The diameter of the diesel exhaust is smaller than of the gas engine.
Also I am looking for sprockets to change the ratio. it is now 1:1.96.. the right ratio for me is 1:1.68
So if anyone has an idea where to find these?  suggestions are more than welcome.
  • 3 uker senere...
Not everything works out fine. Winter was no problem but the heavy rain we got in May.
A lot of water came in to the engine room. And since the tent was waterproof it could only come from
one place. The air intake. I had to remove the cable carriers to see what behind.
Then I poored in some water. and the leaks were visibe. but could not see the crack or holes.
First I tried to fix the leaks with topcoat. But it kept its thick viscosity so it did not flow well.
So to be shure I poored in reson with glass and let it dry.
Now the level is so high that it is no longer possible for water to remain between the deck.
tested again with a litre of water. this time no leaks any more. Pff  :cheers:
Now I am busy with the Volvo transom. doing a refurbish. change all rubbers and repaint that kind of stuff.
also I am looking for a converter so that an electronic throttle can control a mechanical clutch.
  • 2 uker senere...
  • 3 uker senere...
