doctordre Svart 1.August.2017 Emnestarter Link til dette innlegget Svart 1.August.2017 beginning of the end. Link to post
doctordre Svart 14.August.2017 Emnestarter Link til dette innlegget Svart 14.August.2017 number two went in. Both engine are aligned. however with this big step forward it went also a bit backward. The raisers touch each other. the are some bulges in the cast that must be removed to make it fit Link to post
doctordre Svart 23.August.2017 Emnestarter Link til dette innlegget Svart 23.August.2017 Just a few more days. Then the launch is there. everything prepared for the first trip. Toilet cabin. outside. After launch, everything will be tested and software will be expanded with information for the engines. Still waiting for the two exhaust extensions which will solve the exhaust space problem. after that we can turn the key for its maiden voyage. Link to post
Whiskey Svart 23.August.2017 Link til dette innlegget Svart 23.August.2017 Wow that's a tight fit for the engines ? boat looking good! Must be the nicest 9200 around. Up here in the north, the winter is coming and the boats are about to leave the water... ? better post a YouTube of those red monsters running on the water Baltic-pappa Link to post
doctordre Svart 17.September.2017 Emnestarter Link til dette innlegget Svart 17.September.2017 (redigert) Prepaired for launch. My brother made a scketch of the spacers. It took just 4 days, before we got the back. It fitted perfectly, unfortunately I had forgotten the thickness of the exhaust bellows. So I came 3 mm short between the engines. we modified the spacer and after another two days they were finished. That was last weekend. Just had to wait for a new set of gaskets. So on Tuesday the gaskets arrived and everything is now fixed. The picture is dark because is was 21:00 when it was finished. Yesterday checked all the fluid levels. and started everything up. Everything is running well. (video coming soon) There still are some flaws in the software which will be done this week. And coming Friday most likely the maiden launch. Redigert 17.September.2017 av doctordre (see edit history) Link to post
SoBo Svart 17.September.2017 Link til dette innlegget Svart 17.September.2017 Everything looks nice. We look foreward to se her on the water. Stell og oppgradering av en gammel dame (Princess Riviera) Link to post
doctordre Svart 23.September.2017 Emnestarter Link til dette innlegget Svart 23.September.2017 Wow the boat launch is a fact. No problem for the car. The props are F9's. the biggest I could find No leaks. Engines started immediately. The engine bay can be closed soon. How do I feel?? Link to post
SøndreSvaberg Svart 23.September.2017 Link til dette innlegget Svart 23.September.2017 Congrat! Very nice boat! Oppsussing av Draco 2100 SportCab Link to post
doctordre Svart 23.September.2017 Emnestarter Link til dette innlegget Svart 23.September.2017 6 minutes ago, SøndreSvaberg said: Congrat! Very nice boat! thanks. Link to post
Tskjei Svart 23.September.2017 Link til dette innlegget Svart 23.September.2017 Waiting for some numbers?Speed? Link to post
Whiskey Svart 23.September.2017 Link til dette innlegget Svart 23.September.2017 Congratulations! Damn nice Scand! Hope you get some fun rides with it too, or is it all about the build? ?? Baltic-pappa Link to post
doctordre Svart 30.September.2017 Emnestarter Link til dette innlegget Svart 30.September.2017 (redigert) On 23-9-2017 at 9:53 PM, Whiskey said: Congratulations! Damn nice Scand! Hope you get some fun rides with it too, or is it all about the build? ?? Well the build is as almost important for me. Well today we made the maiden trip. Just a short one of about 30 km just to get an impression. Terrible weather but never the less. the ride makes it all worthwhile. Still little thing to do. depth meter and GPS connect to the CAN network. No speed measurements yet, but tested several times the time to glide. A little bit more than 3 and less than 4 seconds. One engine was not powerful enough to glide. However one engine keeps it easily gliding. Just when the throttle goes below 2900 it want to slide back in the water. Redigert 30.September.2017 av doctordre (see edit history) Link to post
doctordre Svart 2.Oktober.2017 Emnestarter Link til dette innlegget Svart 2.Oktober.2017 (redigert) More bad luck. After the trip on Saturday, we did another on Sunday. we took some extra gas. We smelled so gasoline so we decided to to back. and we saw gasoline next to the tank. It was a few centimetres . but today I measured it again and it was 16 centimetre. after opening the tank, there could be only one conclusion. Somewhere there is a whole in it. because the level outside is as much as on the inside of the tank. Redigert 2.Oktober.2017 av doctordre (see edit history) Link to post
Fortego Svart 5.Oktober.2017 Link til dette innlegget Svart 5.Oktober.2017 doctordre skrev On 2.10.2017 at 23.22: More bad luck. After the trip on Saturday, we did another on Sunday. we took some extra gas. We smelled so gasoline so we decided to to back. and we saw gasoline next to the tank. It was a few centimetres . but today I measured it again and it was 16 centimetre. after opening the tank, there could be only one conclusion. Somewhere there is a whole in it. because the level outside is as much as on the inside of the tank. BOOOM!.... https://baatplassen.no/i/topic/107732-viking-conquest-på-nye-tokt/ Link to post
doctordre Svart 18.Oktober.2017 Emnestarter Link til dette innlegget Svart 18.Oktober.2017 Preperations to remove the floor are coming up the weekend. The last picture in the water Link to post
doctordre Svart 18.Januar.2018 Emnestarter Link til dette innlegget Svart 18.Januar.2018 Removed the floor. unfortunately some of the teak had to go. After a lot of screws, the destination. Removed the tank and yes sure the problem revealed. the cause of it all. Corrosion. this is exactly the point where the vent pipe enters the tank compartment. This piece is cut out and another plate will be welded in place. also there is a lot of lost place under the floor. I am replacing the sides further to the outside(in red) and create a little platform on both sides. each side 10 cm extra. But it will create enough room to put large batteries there and saves some storage space under the benches. All the electricity works will be moved under the bench Link to post
doctordre Svart 20.April.2018 Emnestarter Link til dette innlegget Svart 20.April.2018 (redigert) New stringers and battery boxes are finished and the refurbished tank goes back. light at the end of the tunnel. on a normal working day has bigger boats. Redigert 20.April.2018 av doctordre (see edit history) Link to post
doctordre Svart 13.Juli.2018 Emnestarter Link til dette innlegget Svart 13.Juli.2018 (redigert) Everything reinstalled. made some improvements. all fuse are now in one place that is easy to reach. After some trips close by, we took the boat out for a bigger trip of about 100Km. On our way . But not at full speed. We did it slowly and enjoyed the surroundings. Passing a old fortified little town called Heusden. You can go to the centre by boat but it was too busy inside. This a picture at the inside but just on another day. Continuing passing a lock for the first time with this boat. and enjoying the view again Stopped to have dinner and have a swim. Made dinner on the induction cooker for the first time. But it worked perfect and very fast. While enjoying a glass of wine, watching the sun go down . Redigert 13.Juli.2018 av doctordre (see edit history) Link to post
doctordre Svart 13.Juli.2018 Emnestarter Link til dette innlegget Svart 13.Juli.2018 (redigert) The next day we woke up by some strange noises. Did not expect that. but fun to see. After breakfast we continued and pasted anothor fortified town. With real oldtimer ships. perfectly maintained. Continuing on our way to the direction of Rotterdam passing the city of Dordrecht Also with channels through the city. From this place we continued to the direction of home. meanwhile passing colleagues. Backhoe dredger coming home. The trip was wonderfull. Now you would think all's well that ends well "alt er bra som ender bra". Well Not. The day after we cleaned up the boat and it smelled terrible. After some inspection there was a hose disconnected from the dirtwatertank. Then tested the toilet again. Still water came from places where it should not. result Took the floor out and after inspection there is only one conclusion. There is a hole in the dirtwater tank. But we cannot see it. Still not knowing what the top speed is. Fuel consumption was about 130-140 liters. Redigert 13.Juli.2018 av doctordre (see edit history) Link to post
Whiskey Svart 14.Juli.2018 Link til dette innlegget Svart 14.Juli.2018 Good you got to enjoy the trip before noticing the dirt water coming out ?. Is it located in a hard to reach place It's always something ... Baltic-pappa Link to post
doctordre Svart 17.Juli.2018 Emnestarter Link til dette innlegget Svart 17.Juli.2018 Here is the evil of it all. There are many softspots. This tank is beyond repair. Link to post
mthoms Svart 18.Juli.2018 Link til dette innlegget Svart 18.Juli.2018 (redigert) Been there, tried that ... it's rather unpleasant. Now, I had to get a new tank back in the old days ... 2011 it was. I wrote to scand.no and got this answer back: "Hei. Denne kan bestilles direkte hos underleverandør, Thomic Aluminium tlf.+ 47 37027046. " I wrote an email to thor@thomic.no and eventually got a new tank installed. Edit: Somehow your tank looks different from mine ... got to be the difference from a 8600 to a 9200 Redigert 18.Juli.2018 av mthoms Restudy (see edit history) Link to post
doctordre Svart 18.Juli.2018 Emnestarter Link til dette innlegget Svart 18.Juli.2018 (redigert) Its a dirty job and someone has got to do it. that will be me. A new tank is still available at Agder boatshop. But with transport and customs and all, it is cheaper to build one here. The tank is from a 9200 build in 1992. The shape is the same as the water tank. @mthoms : You still got the 8600/9200? Redigert 18.Juli.2018 av doctordre (see edit history) Link to post
mthoms Svart 18.Juli.2018 Link til dette innlegget Svart 18.Juli.2018 5 minutes ago, doctordre said: @mthoms : You still got the 8600/9200? Oh yes ... ain't gonna sell that until the world runs out of diesel... Link to post
doctordre Svart 18.Juli.2018 Emnestarter Link til dette innlegget Svart 18.Juli.2018 Can you tell me about the performance with your diesel although i have gasoline. I did not took it to WOT yet. But in advertisements i see 41 knots with 350 bhp. So I wonder how much is true. Link to post
