mthoms Svart 18.Juli.2018 Link til dette innlegget Svart 18.Juli.2018 doctordre skrev On 18.7.2018 at 11.09: about the performance Vis hele sitatet Of course. First day at the water this year she did 29.9 kts according to my gps. Here later at the season as growing is building and more shoes and bikinies pile up in the cabin, I will get 26-27 kts on a calm day; WOT and 2 persons on board. Cruising at 3100 RPM usually levels out at 18-ish kts. Link to post
doctordre Svart 6.August.2018 Emnestarter Link til dette innlegget Svart 6.August.2018 This weekend first time WOT. Unfortunately no pictures made. i forgot about it. But it did 47knt or 87 kph at 4400 =rpm. The engine stopped there. After some more testing we found out that the fuel line is too long or too small to supply the amount of fuel needed. The fuel chamber between the fuel pump and the high pressure pump is empty quickly after serious acceleration or at wot. So more tinkering to do. pictures next time. Link to post
mthoms Svart 6.August.2018 Link til dette innlegget Svart 6.August.2018 doctordre skrev On 6.8.2018 at 8.20: fuel line is too long or too small to supply the amount of fuel needed Vis hele sitatet Link to post
Kenneth 81 Svart 6.August.2018 Link til dette innlegget Svart 6.August.2018 doctordre skrev On 6.8.2018 at 8.20: After some more testing we found out that the fuel line is too long or too small to supply the amount of fuel needed. Vis hele sitatet Are you sure that is not a feature intended to save your economy? Skibsplast 675 HT med Suzuki DF 250, Biam 800 HT med Yanmar 4JH2-HTE 75Hk Mazda 929, Toyota Celica, Volvo 940GL, Jeep Commander Overland, Volvo 740GL, Mercedes C200 Kompressor, Opel Astra, Mazda CX-5 Link to post
doctordre Svart 6.August.2018 Emnestarter Link til dette innlegget Svart 6.August.2018 Kenneth 81 skrev On 6.8.2018 at 19.40: Are you sure that is not a feature intended to save your economy? Vis hele sitatet Undocumented feature maybe but fuel economy is my project for next year. First run as fast as possible. then Next year the plan is to add a Hydrogen generator. HHO generator but there are issues to be fixed first . Like the swimplatform is leaking when the boat moved backward or when the drive touch the platform. And there some trouble with charging the domestic battery. it takes to long or it does not charge. Dynamo voltage is 13.6-13.8V Charging from shorepower is perfect. Link to post
doctordre Svart 12.September.2018 Emnestarter Link til dette innlegget Svart 12.September.2018 Summer season is almost over. Took the boat for more than 60 hours. I cannot tell exactly because i did not always use both engines. Cornering is fun because of the round hull. But like usual there are things to improve. Battery protection. Sometimes shore power is gone for a few days and unfortunately the charger/converter drains my batteries. Trim Tab. These must be bigger and needs a bigger angel upwards. At full throttle, it remains pushing the noise down to much. Dirt Water Tank. Replace the tank and i change the water tank to so i can finish the floor. Generator. Check the system because the generator stops after a few seconds. Trim sender is not working yet. Engine produces an engine fault on this. Make a step on the swim platform on both side. Getting inside from the deck is terrible. I am getting older. an the height difference between the deck en platform is to much for easy access. Change the depth sensor. I cannot get it to work on my Raymarine e7. Solve some electric undocumented features. Increase the fuel line. Link to post
ivar Svart 12.September.2018 Link til dette innlegget Svart 12.September.2018 doctordre skrev On 12.9.2018 at 14.12: Increase the fuel line. Vis hele sitatet do you know what the inside diameter is on the current line? I've seen fuel line with a kink , get sucked flat from the vacuum from the fuel pump Lurøy / Svalbard. Båter: Gromling 15/60 Yamaha / Wesling 490 m/80 Yamaha / Yamarin 5940 m/ F115 Yamaha / Achilles LS4 (RIP) Aquaquick MS265 West Commando 270 m/ 4hk Yamaha Link to post
doctordre Svart 13.September.2018 Emnestarter Link til dette innlegget Svart 13.September.2018 The inside diameter is 6mm. And the length is 3 meter. And calculation tell me that pressure loss is about 40 mBar. Link to post
ivar Svart 13.September.2018 Link til dette innlegget Svart 13.September.2018 from what I've heard, 6mm is more suitable for smaller outboards. 8mm, 3/8" or 10mm should work much better for your setup Lurøy / Svalbard. Båter: Gromling 15/60 Yamaha / Wesling 490 m/80 Yamaha / Yamarin 5940 m/ F115 Yamaha / Achilles LS4 (RIP) Aquaquick MS265 West Commando 270 m/ 4hk Yamaha Link to post
Jtk1 Svart 13.September.2018 Link til dette innlegget Svart 13.September.2018 way to smal, 0,5 kilo fuel every 100 hp in 1 min ! Link to post
doctordre Svart 13.September.2018 Emnestarter Link til dette innlegget Svart 13.September.2018 129 l/h -> 2.15 l/min -> 1.55 kg/min @ 410 HP close enough http://www.boat-fuel-economy.com/norsk . 10mm it will be Link to post
doctordre Svart 15.Oktober.2018 Emnestarter Link til dette innlegget Svart 15.Oktober.2018 It never ends does it ?! For the last time this season we wanted to make a trip of around 200 km. With a group of 30 boats we planned to go up the North Sea. The weather was good. 25 degrees yesterday. Wind 1-2 bft (<11km/h) . Waves on the sea was less 1.7 meters. Ideal for some fun. We departed and still in the harbor i saw smoke coming out of my dashboard. I quickly pulled my radio out but no sign of a fire. Smoke also came out of my air intake so my company opened the hatch. and yes there it was. My wiring boom was on fire. Just a little but. After taking care of the fire, we try to figure out what caused it because i took the boat out for about 60-80 hours this year. It was the fuel pressure regulator. It started to leak some fuel. The fuel felt on the exhaust and got hot. and therefore the plastic wiring boom caught fire. So 250 meters and that was the end of the trip. Just another point on the list to do this winter. Link to post
doctordre Svart 22.Februar.2019 Emnestarter Link til dette innlegget Svart 22.Februar.2019 (redigert) winter time means tinker time. I made a new display that is sunlight readable and is protected against water. ofcource with CANbus(2x) with finally a boot loader. so programmable via canbus but all electronics is now inside the box. resolution is a bit better 800x480 instead of 600x480. The rest is almost the same. you see a lot of wires but it has about 10 inputs and outputs and there is a possiblity to connect to a camera Redigert 22.Februar.2019 av doctordre (see edit history) Link to post
pero Svart 24.Mars.2019 Link til dette innlegget Svart 24.Mars.2019 Still great works as always. Hope you will get a very good boating season this year. Link to post
doctordre Svart 17.April.2019 Emnestarter Link til dette innlegget Svart 17.April.2019 It floats again. Back in the water last week. It takes a lot of time to change a wire harness. Still a lot to do, but we can sail again. Link to post
doctordre Svart 24.Januar.2020 Emnestarter Link til dette innlegget Svart 24.Januar.2020 Does anyone know what kind of wood is used in the cockpit? it is a multi layer but the layer are thicker than normal and darker thanks. Link to post
doctordre Svart 18.Juni.2020 Emnestarter Link til dette innlegget Svart 18.Juni.2020 (redigert) changes some screen next to the steering colums Added reset button. when there are some electronic issue i can reset hardware without removing the power And a red led give the state of access to the engines. Green when engine is enabled Added start and stop buttons next to the steering wheel This remained the same Added my victron information on screen. when power is on, the voltage and current will also appear on screen Add added screen to dim the lights also create some gauges it will all display the real degrees. rudder new pan tilt gauges and new trim gauge and a G force gauge just for fun there should become a power screen but i have now idea jet, what graphic to use. The information i have is Volts, Amps , Watt and %charged. for all three batteries. Shore current was not efficient on the dashboard but i have it on my ray marine display. Redigert 18.Juni.2020 av doctordre (see edit history) Link to post
pero Svart 18.Juni.2020 Link til dette innlegget Svart 18.Juni.2020 doctordre skrev On 18.6.2020 at 10.58: Added start and stop buttons next to the steering wheel Vis hele sitatet Hm, I see that I have some work to do... Looks fantastic, I am very impressed by your work. Link to post
Kanalkapteinen Svart 19.Juni.2020 Link til dette innlegget Svart 19.Juni.2020 This thread is a fantastic read? What a cool and innovative project! How many hours have you used the boat now since the rebuild? You mentioned something about hydrogen earlier, is that still the plan? Also, where did you run the exhaust from the generator? Tråden om Livet med Windy 8600MC Tråden om Livet med Draco Summerwind 24 Det er vel, det er vel med min sjel. Link to post
doctordre Svart 19.Juni.2020 Emnestarter Link til dette innlegget Svart 19.Juni.2020 (redigert) to Pero: Thanks. Just keep in mind the first rule of technics: IF IT IS NOT BROKEN DON'T FIX IT. I think i never stop changing things. electronics is an even great hobby as boating, maybe even bigger. To kanalkapteinen Also thanks. i used it not so much as i would like but since the launch about 300-350 engine hours. I used the boat more but usually we go somewhere to the beach or forest which is just a few kilometres from here. The advantage of a small county. To make a trip through the forest is about two hours due to speedlimit(~9km) and then we hang around and get some sun. Hydrogen is still the plan. But there are still a lot of things to do. like new trim tabs. And as for the generator. The original exhaust is just a little cap with two screws. a friend copied that but added a little piece of pipe to it so i could connect it with a flexible exhaust and a heat protection around it and drilled the hole thru the hull . between the registration number. will be continued.. Redigert 19.Juni.2020 av doctordre (see edit history) Link to post
Kenneth 81 Svart 19.Juni.2020 Link til dette innlegget Svart 19.Juni.2020 Amazing work on that boat, absolutely love the electronics! Skibsplast 675 HT med Suzuki DF 250, Biam 800 HT med Yanmar 4JH2-HTE 75Hk Mazda 929, Toyota Celica, Volvo 940GL, Jeep Commander Overland, Volvo 740GL, Mercedes C200 Kompressor, Opel Astra, Mazda CX-5 Link to post
Elmann Svart 19.Mai.2024 Link til dette innlegget Svart 19.Mai.2024 doctordre skrev On 11.1.2015 at 19.14: Hello Whiskey, Thank you. Do you mean the connecting terminals and or wiring? For the endpoint like lights and switches i use a 2-wire cable. Since there are some gathing points. the cable is never long. So my cabinlight goes to the domestic module. For the Targa bar is used a 16 wire cable. (nav lights(4), horn, courtesy light, searchlight etc) And as terminal DIN rail terminal blocks with tension spring connection Because more people liked it and also asked for . My brother and i decide to make a complete package for DIY. Vis hele sitatet Will you ever release this complete package for DIY? Link to post
doctordre Svart 18.Juli.2024 Emnestarter Link til dette innlegget Svart 18.Juli.2024 it has been a while. Time goes fast Unfortunately not. The reason is that the costs for production became very high. And also the number of available standard product became better and cheaper. So all the display electronics is replaced this year by a mini PC with a N100 processor. It is a lot cheaper and has more utilities than the electronics made for the displays. This together with a Can/NMEA2000 converter it made things easier to get. (aliexpress has a lot) I used :Chatreey T9 Mini Pc Intel N100 + ECAN-E01 CAN2.0 To Ethernet. + 3 x displays 1000 nits (HDMI) And for the programmers they can make their own display view. As for touch buttons there is now a type 3323-5x (TT electronics) which is a complete button with RGB light and adjustable sensitivity Link to post
doctordre Svart 18.Juli.2024 Emnestarter Link til dette innlegget Svart 18.Juli.2024 Last winter the drives where taken care of. There was a lot of cavitation. The edges of the blades became blue. I added a 1 inch spacer. The cavitation is gone or at least I cannot hear it anymore Also the gear ratio is changed from 1:1.95 to 1.78 it increased the speed a bit With the test I did not go all the way (WOT) but at about 4350 RPM both I got to 92 km/h Engine Computer indicated 90% throttle given. Link to post
doctordre Svart 3.April Emnestarter Link til dette innlegget Svart 3.April Big Setback. Soft wood in the transom. While installing drilling holes for the new tabs, water came out. That is not a good sign. To find out where the problem is I made so probe holes in the floor bottom. Al lot of water came out. A piece of the flat floor remove and found that the wood was wet and soft . So i decide to remove the while floor side. After clearing and clean there was no crack or hole to the outside of the boat. But I found a little hole in the transom polyester connect with the floor. I removed a little piece of wood from the transom. Unfortunately it was black and soft. after removing a bigger piece it showed that the wood of the whole starboard side was wet. it still had strength. But it needs replacing the wood. Now everything is removed When removing the transom the cause became clear. see last photo. Water leaked along the thread of the drive into the transom plate and in between the plate and the drive. now continuing fixing Link to post
