doctordre Svart 31.Mai.2014 Emnestarter Link til dette innlegget Svart 31.Mai.2014 As allways, nicely done doctordre. I liked the trick you used on the waterpipes to separate hot from cold. This project must be a costly one? superclean wiring n pipe work!! It is not so expensive as it looks. But I rather do it well than half. So it takes more time than I wanted but it will be certainly be worth the effort. We see, probably at the end of this year. Link to post
doctordre Svart 14.Juli.2014 Emnestarter Link til dette innlegget Svart 14.Juli.2014 Several weeks passed. Most of the work is now invisible. And carpentry is now my best skill, so with some professional help, I am changing the panel with mahogany wood. it takes a lot of patience to get them well. ( 8 layers of varnish) this is an example of the panel in the toilet. in the mean time, (between the varnish paintjobs) the kitchen gets it new shape. Before: Up till now: The new fridge is 75 liter total. 10L freezer and 65L refrigerator. And for comfort, the compressor is external and I put it under the seat outside. So the noise is less at night, and the heat will remain outside the cabin. For the technicians: it is a C75L VITRIFRIGO. 12V 2,8A. 34Watt and it needs about 340Watt per day. A cold buffer is optional. Due to the new fridge and (induction) cooker, the whole kitchen dresser went up by 5 centimeter (2 inch). for the space there is, it is quite a lot, and it clearly noticeable. However for me personal it is easier to use it. I am 2.00 meter tall so I don't have to bend down so much. It felt a lot better for my back. Link to post
doctordre Svart 21.Juli.2014 Emnestarter Link til dette innlegget Svart 21.Juli.2014 the glass dash arrived: steering wheel dash top dash top dash Link to post
edo Svart 26.Juli.2014 Link til dette innlegget Svart 26.Juli.2014 Very nice Sollux 24 AC Scand Baltic 29 Scand 360SE Link to post
doctordre Svart 22.August.2014 Emnestarter Link til dette innlegget Svart 22.August.2014 The dash slowly comes to life. sorry the pictures are not very clear . but i hope you see the result. The first row is connected and de light intensity is 20% in the first picture. The colour is yellow at this moment. but in the end it will be blue. because i didn't had the blue LEDs yet. when i press a key the intensity of that specific key will be 100%. (like it should nothing special) With circumstances when you have the dashbackligh almost maximum(here is 80%), you almost don't see the difference between 80% and 100%, so in this case the system works reverse. When you press the button the light will go off for that moment. You probebly are missing several buttons. like navigationlight ed. But these will be controlled by the Touch display of this dash. There is more flexibility since buttons and switch can be added or removed. Link to post
doctordre Svart 3.September.2014 Emnestarter Link til dette innlegget Svart 3.September.2014 The display came to life. a close up. it is also a touchscreen. Now i can start writing the rest of the application Link to post
trekko Svart 3.September.2014 Link til dette innlegget Svart 3.September.2014 Thanks for sharing such a interesting project! Link to post
doctordre Svart 3.September.2014 Emnestarter Link til dette innlegget Svart 3.September.2014 Thanks for sharing such a interesting project! Thank you. / Takk. I hope to get some more ideas. Link to post
doctordre Svart 26.September.2014 Emnestarter Link til dette innlegget Svart 26.September.2014 Toilet finished. replaced the old toilet so now it is electric. And the replaced some panels by mahogany wood. With of cource the lots of varnish layers. Also all the hoses are now below the floorboard. before after next subject kitchen. Link to post
baatsman Svart 26.September.2014 Link til dette innlegget Svart 26.September.2014 Nice Vi sees! Link to post
doctordre Svart 7.Oktober.2014 Emnestarter Link til dette innlegget Svart 7.Oktober.2014 The engine dashboard has power. it works from 10V to 30Vdc. So no problem if somebody connects 24Vdc the blue buttons to switch on /off the displays and stopping and starting the engine and some other jobs to do. small and big Link to post
Roger og Olina Svart 8.Oktober.2014 Link til dette innlegget Svart 8.Oktober.2014 Wow... Link to post
Jangul Svart 8.Oktober.2014 Link til dette innlegget Svart 8.Oktober.2014 the glass dash arrived: steering wheel dash top dash top dash Where did you buy the touch panels?? Link to post
doctordre Svart 8.Oktober.2014 Emnestarter Link til dette innlegget Svart 8.Oktober.2014 Where did you buy the touch panels?? Hello Jangul. I got the question before, by mail. The design is my own. With help from a friend who uses AUTOCAD. He made the drawings for the aluminium and the glass from my design so that a machine could produce it. The wingbuttons I made them with the help of a program inkscape. Then the glass is made by a company in Belgium. it is tempered glass. the text is not printed, but burn the glass. this way, black in really black and not transparent. as for the electronics and software. The electronics is made by a company called VETH. and the software for it I wrote myself. All the parts are glued together with window-glue that is used in the car industry. So for the time being it is a one of a kind. However all the drawings and software are designed for serial production. Inside the boat there are four hotspots. engine PS and engine SB are interfaces that read temp, press and voltage sensors and can start and stop the engine and control the trim and tabs. they are connected with the PS and SB display. the steering wheel dash controls all the domestic system. so the domestic hotspot switches on the lights and other things and read the water level. the GPS is connected with the centre display. and also connected with the last steering wheel hotspot. so from the steering wheel it is possible to kill the alarm buzzer from the engine, dim the lights off the displays and send special commands to the engine(bay) like set trailer position, cruise control, start generator and things like that. Link to post
Jangul Svart 8.Oktober.2014 Link til dette innlegget Svart 8.Oktober.2014 Thank you for the answer :) The work you are doing on the boat is really great:) Inspirational!!!! Link to post
doctordre Svart 22.Oktober.2014 Emnestarter Link til dette innlegget Svart 22.Oktober.2014 (redigert) The kitchen is getting into shape. The beginning with just a board of wood after sanding and varnishing and sanding and varnishing and......8 times it started to look good. The top board has a HPL layer. So it is water resistant. Before reinstalling the shelf on top , some lighting and the support for the drawer needs to be installed first. The induction cooker is 3100W in total and gets its power from a Victron converter. Also a power socket will be installed on top for something like a coffeemaker of microwave or other kitchen appliances. Or to charge a laptop. Between stages, the support connectors are glued in to hold the electronic PCB for the dash. on top are the PCB's . Redigert 22.Oktober.2014 av doctordre (see edit history) Link to post
doctordre Svart 26.Oktober.2014 Emnestarter Link til dette innlegget Svart 26.Oktober.2014 The little things in the kitchen, like lights. And of course "Size do matter" 2 cradles of beer without problems fits the cabinet In meantime the helm seat was ready for overhauling. unfortunately the mainstay(the foot on the floor) is so much corroded that it is almost impossible to restore it. So I was wondering if anyone know the brand of the mainstay? Link to post
doctordre Svart 30.Oktober.2014 Emnestarter Link til dette innlegget Svart 30.Oktober.2014 kitchen ready (finally) Link to post
Båttransport D5L Svart 30.Oktober.2014 Link til dette innlegget Svart 30.Oktober.2014 Nice Link to post
doctordre Svart 23.November.2014 Emnestarter Link til dette innlegget Svart 23.November.2014 the steering is replaced by an hydraulic system and also can tilt the steering wheel. Most work is now invisible now. it's connecting all the equipment to the network. And testing that no mistakes are made. But it still happens one a while. Link to post
Øya Svart 23.November.2014 Link til dette innlegget Svart 23.November.2014 Nice work Man behøver ikke å være lei av den gamle, for å ha lyst på noe nytt. Link to post
doctordre Svart 17.Desember.2014 Emnestarter Link til dette innlegget Svart 17.Desember.2014 dashboard wiring is finished. Here are the pictures before: So to be honest, nobody could do worse. Here you can see the main wires 1- Throttle 2- domestic network 3 and 4 engine network The two black ones is the tubing for the steering wheel. The hole is close with a Raymarine GPS(e7). I choose for this option because I don't like to put the additional devices on brackets. The are already so many holes. During the Christmas holiday I will do the programming of the network. So that's it for now. I want to wish everyone in Norway a happy holidays and best wishes for the 2015. Link to post
Møkkalasset Svart 17.Desember.2014 Link til dette innlegget Svart 17.Desember.2014 Nice and tidy! Looking forward to the finishing work. Merry x-mas! Link to post
SoBo Svart 17.Desember.2014 Link til dette innlegget Svart 17.Desember.2014 Nice work you are doing, It is good get control over this wiring. This we take in norwegian: God Jul Stell og oppgradering av en gammel dame (Princess Riviera) Link to post
doctordre Svart 17.Desember.2014 Emnestarter Link til dette innlegget Svart 17.Desember.2014 In dutch: Vrolijk Kerstfeest en een Gelukkig Nieuw Jaar. Or Russian: (ex-wifes family) С Рождеством и Новым Годом. [s rozhdestvom I novìm godom] Although Christmas is in January in Russia. Link to post
Opprett ny konto
Gratis og helt uforpliktende
Logg inn dersom du har konto
Logg inn
